Ring gear carnage....PIC's!
Discussion in 'The Garage' started by stallion85, Jul 8, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Ring gear carnage....PIC\'s!
    OK, I just got a great deal on a D44 front axle with chrom moly shafts, ctm u joints, ARB locker, crossover steering, rock stomper tie rod, and diff protector. $400 for the whole shabang. I got it home and popped the diff, oh no!!!!! The ring gear is chipped pretty bad. I cleaned it out and turned the yoke with no problems, it cycled smoothly. I need to get a new ring gear, right? I am afraid to hear the answer. I am not pissed, I mean all the other stuff is a great deal. If I bought a new ring and pinion what would be an average price to install with my ARB in there? Could a rookie mechanic take the carrier out and take it in to get fixed? Any ways heres the pic....
    [​IMG] [​IMG]
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Re: Ring gear carnage....PIC\'s!
    You have to replace the ring and pinion together so you can't just take the carrier into a shop. You need to take the whole thing. I've seen regears cost from $400 including gears to $800 not including gears /forums/images/graemlins/eek.gif Thats why I do my own.
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I would be concerned about metal in the ARB damaging the O-Rings.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    That's the problem with beefing D44s and 10 bolts - the ring gear becomes the weak link. I did that to 2 ring gears in my D44, they looked almost exactly like that. Whoever you bought it from probably had tires on it that were just plain too big for the 44. You definately need a new gearset. I'd be a little concerned about the fact that they cut half the width of the bearing cap off to clear the ARB line, that looks really excessive.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Too late now, but that is why you should ALWAYS pop the cover and peek inside before handing over any cash for an axle. /forums/images/graemlins/angryfire.gif That said, with that much metal floating around in there, I would get a new ring and pinion, a master install kit (new seals, bearings, shims, etc.), and an ARB rebuild kit. The hard facing is probably damaged on the bearings and ARB's absolutely HATE contaminated lube. /forums/images/graemlins/frown.gif Fix it right and you'll only have to fix it once. /forums/images/graemlins/thumb.gif
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Nice catch Shaggy! I was so busy checking out those mangled ring gear teeth that I didn't even notice that! /forums/images/graemlins/yikes.gif
  7. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    You may have to put another $400 in to it, if you do the work yourself, but I think you still got a pretty good deal for all that stuff.
  8. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Do they make rebuild kits for ARB's? I can't find them on the web???? Well my Father in law says he can change the ring and pinion. So all I will have to do is buy the kit. I am still ahead either way.
  9. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    From 4 wheel parts I can get a master install kit and new ring and pinion (precision gear) for around $225. Would you guys pay the extra dough and buy a beefier brand?? If there is a such thing?
  10. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    $400 is still a good deal on that axle, ask some of your buddys if they know anyone some guys can do that for a freinds freind for for a little cash... just make sure they know what there doing
  11. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    Are 35" tires too big? /forums/images/graemlins/dunno.gif I was going to build up my D44 simular to his, thats why I ask. /forums/images/graemlins/confused.gif
  12. fad2blk99
    fad2blk99 1/2 ton status
    Feb 19, 2001
    860
    Charleston, SC
    Get on ebay... check out some of the stuff on there before you buy rebuild kits and stuff. I save $50 bucks on my d60 rebuild kit (w/ Timken bearings). I also got a d60 Richmond gear 5.13 gear set for $125 (installed but never used). I imagine 1/2 ton stuff could be had for dirt cheap. Beware though, there are a few bad deals on there too.
  13. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    I killed mine with 38s, 35s should be fine...
  14. backcountry
    May 27, 2004
    916
    Thank you! /forums/images/graemlins/waytogo.gif
