ring gear change
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87 mid canada k5, Jul 25, 2000.
  1. 87 mid canada k5
    87 mid canada k5 1/2 ton status
    Jul 20, 2000
    105
    Winnipeg Manitoba Canada
    anybody change the ring gear for their starter lately? do i need to pull the tranny out or can i get away with maybe just sliding it back? I've got a bad spot that shows up once every 5 or 10 starts.
    ( FORD backwards- driver returning on foot) '87K5
  2. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    auto or standard?
    your right. I don't understand the jeep thing!
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Are you sure it's not a flat spot on the armature of the starter? That would give you a dead click (or no click) when you try to start it. Need to replace/rebuild the starter if that is the case.
    <font color=black>'79 K5 - 406 w/IROC TPI -<font color=orange> K5#5 - <font color=blue>http:// www.blazzinor.coloradok5.com
  4. 87 mid canada k5
    Jul 20, 2000
    105
    truck is an auto, and i'm pretty sure the starter is good it's fairly new. i think my last starter was too tight and should have been shimmed out a bit ,it eventually burnt out and seeing as the starter gear is harder than the ring gear i think it got a bit chewed. 87midcan.k5
  5. 87 mid canada k5
    Jul 20, 2000
    105
    p.s. the noise i'm getting is similar to the sound you'd here if you tried to start it when it was already running (not that i've ever done that ! ;)
  6. MyK-5
    MyK-5 Registered Member
    Jun 18, 2000
    50
    Phoenix
    You need to put shims on it. My starter did the same thing. I put a few shims on there and it purrs like a kitten
    81 Beater
  7. bablazer73
    Apr 4, 2000
    3,363
    upstate ny
    if you get 4 3/8 bolts approx 8" long and put them in the bellhousing bolt holes, put a jack under transfer case/trans, remove crossmember, drive sharfts, undo torque conv. you can slide trans/transfer assembly back enough to replace the flexplate/ring gear without fully removing the trans. although it will look like the trans will just about come out. depending on what version of front exaust pipe/ crosssover you have, you might have to play with exaust. you might also have to put another jack under the engine to support that while trans is loose. either way, not a fun job.
  8. 87 mid canada k5
    Jul 20, 2000
    105
    thanks guys, i did try shimmimg, didn't work. so i'll give the long bolt method a go, running dual exhaust with no cross-over pipe, so maybe i'll get lucky and it won't be too bad. Bloody knuckles here i come!
