Ring gear replacement
Discussion in 'The Garage' started by big83chevy4x4, Oct 18, 2005.
  1. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    has anyone replaced their own ring gear? im worried about not welding it 100% and throwing the ballance off and destroying the motor.
    or should i pay someone to do it and hope they do it correctly?
  2. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Do you mean flywheel or flexplate?
  3. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sorry, i guess i forgot that part, flywheel.
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    stick or auto?if auto thay are cheep new.
  5. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Flywheel ring gears are not welded at all, they are just sweated on. Get yourself a punch or chisel and knock the old ring gear off then take the new ring gear and heat it with a torch by going around it in circles as it lay on the flywheel and when it reaches the correct temperature it will fall into place and as it cools down it will grab the flywheel and stay tight. :thumb:
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    hmm, i swear i seen a weld somewhere on there. i guess i seen too many flexplates and figured the flywheels are also welded on.
    that sounds easy enough to replace.
    thanks, thats one less thing to worry about.
