Ring Gear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Smitty, Oct 5, 2000.
  1. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Is there a place online that I can cross a GM part number off a ring gear to tell what ratio I'm running?
  2. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    whats the number i might be able to tell u.
    <font color=red> Hey who put that grenade in there? </font color=red>
  3. 67firebird400
    67firebird400 Registered Member
    Sep 24, 2000
    18
    Smitty why dont you just count the teeth on the Ring and the teeth on the Pinion, compare that to what a shop manual says (ie. my 'Bird is a 3.08 ratio = 40ring gear teeth&13 Pinion gear teeth) 40 divided by 13 is 3.08 Try this before youre pullin your hair out lookin for that little number on the big gear.
    I think I dropped that grenade in there when we did the locker Stu. WHOOPS!!! >:)
  4. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    if he didn't already have the number then why would he be looking for a web page to put it in to see he ratio?
  5. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    The part number on the ring gear is 464919 45-11(last part may not apply). Tried to check it out in the parts book but it looks like the ring & pinion are sold in sets that don't match the number. I've found a KJJ code on the axle tube. The only reference to this code is for a 1979 CK 20 series. Can I assume that this axle came from a 79 or is this code used in other years? If this is right and it has the stock gears I should have a 4.10 w/posi.
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Yo ucan also check the RPO codes on the glovebox sticker.
    These are the ones I remember
    GT4=3.08
    GU6=3.42
    G80=Gov lock (posi)
    90K5
  7. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    The last part of your number (45-11) is your tooth count. 11 teeth on the pinion gear, 45 on the ring gear. 45 divided by 11 equals 4.09 which is commonly called 4.10s.
    Cruisin in my '73.
  8. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Thought that was the easy way out but someone helped me out by putting a 14 bolt FF in the back. I'm not complaining but I'm just getting started with this one and am showing signs of mismatched gear ratios between the front and rear. Shouldn't be a problem since I haven't able to get off road and really use it yet. I just need to find out before I can use the 4WD.
  9. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    Thanks for the info, now I can put it back together and check the Dana in the front.
