Ring&pinion Carrier
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by paul123, Aug 23, 2003.
  1. paul123
    paul123 Newbie
    Aug 13, 2003
    3
    Illinois
    I'm changing a ring/pinion on a stock 10-bolt (I know) ratio of 3.42. I've removed the carrier and have the old ring gear off. The photo attached is the opposite side of the ring gear and syder gears. My question is....is this normal???? The center area has a depressed - almost worn where the axle enters the spyder gears. Can any one familiar with this provide any advice about the condition of this part???? HELP !!
  2. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    Photo?
    /forums/images/graemlins/thinking.gif
  3. paul123
    paul123 Newbie
    Aug 13, 2003
    3
    Illinois
    Sorry about the photo, having problems putting it on a webpage....
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    spiders rideont he pinion lock shaft, the wcrew you have to remove to pull the shaftout to let the spiders go screws into the holeint he sideof the lock shaft, sometimesclaled pinion shaf,tbut dont confuse that with pinion gear or pinion stem,
    wherein IL are you ? imin lincoln, on i-55
    what kindof wear ? flat spot wear ? blue or black heat spot wear ? scuffing ?
    are you simply replacing 3.42 with 3.42, or ?
    goodluck
