Ring & Pinion slack
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rcpilot, Jul 19, 2004.
  1. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Got my 12B rear cover off to replace my axles and wheel bearings... the gears look great, no cracks/chips, it seems like there's alot of play between the R&P.. how much should there be and if there's too much can I re-shim the pinion... the vehicle has about 200,000 on it, but the gears don't look like it...
    Thanks...
  2. 4X4HIGH
    Dec 14, 2001
    22,058
    69
    Pleasanton, CA.
    Backlash should be somewhere around .004"-.008" of an inch.
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the backlash should be about .005-.008" yes you can shim it to get it to specs.
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Since the gears are worn in the way they are, it is not a good idea to try to change the backlash. You would change the shims on the carrier side bearings to change the backlash, but you shouldn't do it. If the gears have even a small amount of wear and then you reduce the backlash, you will make the pinion ride up on the ridge that is worn into the ring gear. This will cause all of the load to be carried be the very end of the pinion gear teeth, leading to broken teeth. Changing the pinion depth will change the gear engagement pattern - you would only do that if you run a pattern and see a problem.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Since it is a bit worn, 200k, backlash should be a bit more the .008-.010, which is spec for a new gearset. What is it?
