Ring & Pinion whinning/humming noise
Discussion in 'The Garage' started by la_blazer82, May 20, 2005.
  1. la_blazer82
    la_blazer82 1/2 ton status
    Apr 12, 2004
    148
    SoCal
    Could this be from the gear set themselves (bought Genuine Gears from 4WParts - that's all they carry), or is it the install? I've read up on some install articles, and there is mention of possible noisy gears if they are set up too 'centered' (?) or incorrectly. :confused: There is no other noise or problems, other than the humming/whinning noise
    I in no way will do this myself, just want to know possible solutions. Humming starts at about 45-50 mph
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I'm sure someone more knowledgeable will jump in on this like Readymix, but I believe that a loud humming is badly set gears. Check the case to see if it's getting hot. If it is then you've got a prob. I think I remember reading that some gears are noisier than others but I don't know by how much. You could drop the cover and see how your contact pattern looks and look for signs of heat. Good luck.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Theres your answer. They are crap gearsets. Dont set up very good and, well, noisy.
    It could be bearings, but there more of a high pitched noise.
