Ripped the HD shackle bushings...Again.
Discussion in 'OffRoad Design' started by thebigdaddyof2, Aug 24, 2005.
  1. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    I must be hard on ORD shackle bushings.
    After the first greasable set failed, I tried the new, harder compound bushing set. They lasted longer than the originals but I have somehow ripped and mangled those as well.
    Do you guys have anything other than the HD black bushings to try?
    Should I call and just order a new HD black set?
    Thanks,
    todd
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What are you torqueing the bolts too? Should only be 45 ft lbs.
  3. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    A buddy of mine has cracked his before, I think its because the bigger bolt doesn't leave enough material for the bushing to withstand given forces.
    Just a thought, might be totally wrong :o
  4. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    dunno if it matters, but i went trough blk then yellow and im on red now and they are holding up fine so far :dunno:
    also makeshure bolt sleeve and bushing are all right size- snug should slide in byt no slop
  5. GREENEJEEP
    GREENEJEEP Registered Member
    Feb 27, 2005
    16
    HASTINGS FLORIDA
    Are you running a hardpan bar? You might need one.
  6. project84k5
    project84k5 Registered Member
    Sep 14, 2004
    40
    Fort Worth, Texas
    im not really sure what a hardpan bar is, maybe a sway bar, but i have gone through several sets of the bushings myself, im on my 4th set, but i have noticed that when i do more street driving, they seem to last longer, so maybe it is a lack of bushing area and maybe have something to do with how much flex the trucks have, i dunno....
    ryan
  7. GREENEJEEP
    Feb 27, 2005
    16
    HASTINGS FLORIDA
    I have always had prob's in the past with front end bushings untill I started running a panhard bar. A sway bar will not do as effectively as such.
    The panhard should connect to one side of the frame and drop across to the opposing side of the same axle. You may need to fabricate the set up. I do belive ORD supplies these bar's. Make sure you keep a line as level as possible across the front end for flex up and down. I used a panhard from the rear of a TJ Jeep. I can send you a pic if you want to your personal e-mail, I cant post pics here.
  8. GREENEJEEP
    Feb 27, 2005
    16
    HASTINGS FLORIDA
    cegusman, that IS the SICKEST avatar I have ever seen. :haha:
  9. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Stephen,
    Got any suggestions?
  10. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
  11. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,953
    248
    Released from Pueblo, told I belong in Southpark
    Aren't the shackles supposed to be able to move within the frame?? Or am I more than 1/2 a bubble off??
    If so are bolts too tight on frame?? :dunno:
  12. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    There's just not much space to work in with either factory eye. I have some ideas on how to improve the bushings a little but we're still dealing with a small hole that has a big job to do. I hate to say this but at this point, they're a replacement item from time to time.
    The bolt and sleeve size are set to leave as much bushing as possible while leaving some strength in both. In fact, we went to a 4130 chromoly for the tube to help keep them from crushing and to get some more consistent material in that area. The real answer is new bushing mounts for the top and new main eyes on the leaf spring along with a longer shackle to make it all fit under the frame rail but that's a lot of modifying.
    It is a matter of twist, under more "normal" conditions, the bushings will last for years, some hard trail riding with lots of twisting on the front springs and they'll split.
  13. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Anyone tried rubber bushings? The springs that twist hardest on my truck are the 57" rears, and the factory rubber bushings are holding up better than any poly bushings I've had...
    :dunno: :dunno: :dunno:
    Rene
  14. thebigdaddyof2
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Hmmm.
    I know the OEM and Aftermarket springs are gonna use diff size spring eye bushings.
    Anyone have a part # or application for rubber bushings that will work in aftermarket springs using 1/2" bolts?
    Hell, at this point, I'll give them a try if I can find them!
  15. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The problem with rubber is the rotation, it can't rotate without tearing since all the parts are bonded together.
  16. lifted78chevy
    lifted78chevy Newbie
    Apr 25, 2004
    SA, Texas
    Yikes that is GROSS......where did u find that thing......it makes u wanna puck but its cool to watch....LOL
