rivit in crossmember
Discussion in 'The Garage' started by PeteH, Jan 23, 2004.
  1. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
    i took out a rivit out of my crossmember and it was all smudged looking.like someone smeared the rivit(rivit was stretched and stuff and wasnt straight anymore)...now the holes dont line up, i tried to turn my wheels left and right, put a wheel up on something hoping my frame would flex enough so the holes would line up. i know other people had problems like this..just wondering what you guys did to make the holes line up so i can stick a bolt in there?
  2. PeteH
    Mar 26, 2003
    498
    San Jose
    comon people i need help!!!!
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    what cross member is it? would a big c clamp work?
    grant
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Could you just drill the holes out bigger and put a bigger bolt in there?
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's what I'd so. Be sure it's a high strength bolt.
    One day I'm going to get bored and go at my frame with an air chisel, torch, bolts, and a welder and eliminate as many rivets as possible....
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    drive a drift punch in the hole, clamp it with a c clamp then remove the punch and replace with a bolt.
  7. PeteH
    Mar 26, 2003
    498
    San Jose
    its the front crossmember
    I'm gonna combine the two ideas.
    thanks for the ideas u guys! /forums/images/graemlins/thumb.gif
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    drill it 3/8" of an inch and get 3/8" boilt
    done, and if you have access to a welder then weeld everything up to prevent extra flex, if its bad, i guess that depends on where how you drive truck
    good luck
  9. PeteH
    Mar 26, 2003
    498
    San Jose
    is 3/8 really good enough?i shouldnt go with 3/4? /forums/images/graemlins/confused.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd say you're going to use a 7/16" or 1/2" bolt in a hole that you took a rivet out of. Use a grade 8.
    You'd have to drill a pretty big hole to put a 3/4" bolt in.
  11. bgchvy79
    bgchvy79 1/2 ton status
    Jan 3, 2004
    108
    Moore, SC
    When I converted my 4wd to 2wd, most of the rivets I had to replace were 3/8"
  12. dyeager535
    26,979
    If you really want to get fancy, after getting the two holes lined up, you can tap it. Between the two pieces of metal I was able to get about two threads. Probably doesn't help much strength-wise, but tightening the HECK out of the nut is a lot easier that way, and so was getting them lined up when I released the clamp.
  13. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I took EVERY rivit out of my frame and replaced them with 3/8 (where appropriate) grade 8 bolts and tightened the snot out of them. I do truck pulls and since then have broken axles, transfercase adapters, motor mounts, etc. and the frame hasn't even shifted (I used a grease-pen to mark seems to see IF it would shift and it didn't). I didn't get a chance to pull last year, but I'm heading into this year with a BBC instead of the built small block, so I will see if that has any effect on the bolts.
  14. PeteH
    Mar 26, 2003
    498
    San Jose
    i used drift punch to line up the holes, then jammed a piece of pipe in between my frame rails to push my frame apart and keep it in place. Then i drilled and tapped it, stuck a grade 8 bolt, lock washers, nylock nut thing, and lotsa locktite.Thanks again
