RMS question
Discussion in 'Audio' started by MudFrog, Mar 17, 2003.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    My subs can handle 125w RMS, I'm looking at a Kenwood Amp that supports 150w RMS when bridged, is this going to burn up my subs? I know it's only a 25w difference but better safe then sorry.
  2. pplblazerdude
    pplblazerdude 1/2 ton status
    Jul 18, 2002
    242
    Kingsport, Tennessee
    it shouldnt if u dont run them with full power on the amp it will have controls to control it and u can turn the power downt to them and it would be fine.
    Clint
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    You'll be fine......
    Don't get TOO stressed out over the "spec" stuff....it will be virtually IMPOSSIBLE to generate a signal that will pull a continuous amount of current from any amp!
    You are more likely to blow a speaker with too LITTLE power, than with too MUCH power.... if the amp goes into "clipping"....that's when speakers get damaged. If you really care to know the reasons, I can get into it more....but your simple answer today, is that the amp and speaker combo you are looking at will be fine. /forums/images/graemlins/thumb.gif
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Simple answers are very good!
  5. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    yeah don't worry about over power..i run 2 12inch jl audios that are rated about 125rms..and i'm running a 500watt rms amp to each one..total of two amps..and it pounds the heck out of everything...and no problems
  6. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    it better to over power them, over uder powering them and trunning the Vol up to high.
