road noise
Discussion in 'Audio' started by ONE2PLAY, Mar 13, 2002.
  1. ONE2PLAY
    ONE2PLAY Registered Member
    Oct 2, 2000
    34
    Bakersfield California
    What causes it. It started all the sudden an now is pretty loud.
  2. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    that's a REALLYYYYYYYYYYY broad question. where is the noise coming from? What type of noise is it (tires,wind,engine,etc)? Did you change anything right before the noise started? etc etc etc....
  3. ONE2PLAY
    Oct 2, 2000
    34
    Its a winding noise coming out of my speakers. The higher my rpm's are the louder the noise. Would a ground wire cause this?
  4. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    That sounds like "Alternator Whine".....a buzzing in the speakers that increases with the RPMs of the engine.
    Usually caused by a "ground loop".....it IS an electrical problem. What have you installed recently? My guess is either a new stereo, amp, etc.
    The ground is probably at fault. You'll need to find a quieter spot on the frame to ground it, and "NO" the negative post of the battery is not a good place to ground your amp......(I'm quite serious about that!)
  5. ONE2PLAY
    Oct 2, 2000
    34
    thank you
