Roadmap your vehicle mod plans here:
Discussion in '1936-Present Suburban' started by Ddragggon, Sep 23, 2002.
  1. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    allrighty, since I'm bored, and looking for ideas, I'm gonna start a thread, and make you guys come up with ideas/share what mods you want to do/mods you have done to your suburbans to make the supreme vehicle that much more supreme ( supremer? )
    what I have: 1973 K20 suburban. 350/350/205, 4 inch lift, blocks in the back. 33x12.59-16.5 AT tires on wagonwheel rims. spray on rubber truckbed lining for paint, and finaly have all the windows in it.
    Mods I plan on:
    -replace tired 350 before the mains fall out of it with a happy 454. ( found bearing dust when I changed oil last time)
    -replace TH350/205 combo with something that'll hold up to a 454's brute strength punishment. thinking along the lines of SM465/205 combo for now, possibly NV4500 or NV5600 when I have the time/loots.
    -replace old crappy block lift with 6 inch springs all around.
    -Dana 60 front, crossover steering and etc.
    -35 to 38 inch tires, because 33's look puny.
    -power doors, because cranking windows sucks.
    -AC charge, because this is Arizona afterall
    -make stereo fit the rear better: currently just a massive speakerbox that takes up too much room. want something that fits allong the sidewalls, so I can still carry people/stuff.
    -better seats
    -roll cage(?) (not really nessicary on suburbans, as they've got 8 window pillars)
    -doubler? trippler? overdrive?
    -internal toolbox storage racks, welded/bolted in place, and custom fit to hold the tools and parts.
    -disc conversion for the rear (have the brackets, just need to get the calipers, brakelines, rotors, and time)
    not sure what else I want t odo, so everyone else chime in with pictures, ideas, and stories.
    -Rich
  2. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    Here's what I have planned for when I do get my own Burban and have enoguh money to do anything with it...
    87-91 3/4 ton Burban
    4" springs in front
    4" shackle flip in rear
    Dana 60 front w/ crossover steering
    4 Rancho 9000 shocks on rear axle
    454 TBI dunno bout tranny NP205
    headers & flowmaster dual exhaust
    snorkel
    4.56 gears
    35" BFGoodrich M/T on 16.5" rims w/ safety bead
    CB/PA system
    CD player
    Internal rollcage
    Cargo rack on top made out of same tubing as rollcage and attached directly to rollcage so it can support full weight of vehicle
    2 super bright KC lights to front, 2 to corners, 1 bright on each side, 1 bright in rear (all lights inside roll cage so they dont get squished during roll)
    Racing seats in front w/ 5 point harnesses
    Rhino lined cargo area
    Chery red paint job with 3D blue flames
    2"x1" steel tubing rockers
    chainlink steps hangin from rockers
    Custom front grille gaurd and rear bumper w/ 5 2" receiver hitches
    12000 pound winch mounted on 2" hitch so it can be mounted where needed
  3. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    ok this requires two lists, long term and short term.
    short term
    - get 2" body lift installed this weekend
    - get the 4.56s installed
    - get the 4" shackle flip rear installed
    - finsh priming the outside to make it all 1 color
    - paint inner fenders flat black
    - paint certain parts chevy orange
    - replace stock speakers before the alpine stereo destroys them
    - fix front driveline vibes
    - sliders
    long term
    - go up to 6" springs front and 2" springs out back
    - get rancho 9012s
    - doubler
    - new motor, hopefully a 383 or caddy 500
    - springer rear suspension
    - internal 'cage
    - some kind of good looking snorkel
    - 38" to 42" TSLs
    - possible 4-link coil-overs
  4. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    lets see... gotta finish the engine. gonna stroke the 350, get msd, bigger carb, and some other tweaks here and there. Still gotta finish my front fenders and start on the engine box so I can get it sprayed with line-x.
    Oh ya, my springer suspension is currently being built.
  5. holyjohnson
    holyjohnson Registered Member
    Nov 22, 2001
    94
    the fringe of insanity (only on mondays)
    85 gmc sub 1/2 ton 4x4
    p/w,p/l,p/s,rear air,deep tint,burg cloth int.
    300 hp 350ci.
    edelbrock air gap manifold
    shorty headers w/ exhaust dumps
    dual exhaust w/ walker hemi turbo mufflers
    ?110 hp shot of nitrous?
    tci truk-master 700r4
    atlas overdrive
    np-205
    D60 front air locked 373s
    C14 bolt 373s
    hydro boost conversion
    4 wheel disks
    2" suspension lift (yeah,just 2 inchs)
    35" BFGs w/eaton beadlocks
    rock sliders
    on board air/welder
    dual battery conversion
    s.e.c. winch bumpers
    warn 12000 winch
    waldoch conversion seats,console
    overheard console,hi-topp.
    custom 8-10 point cage for front and rear seats.
    raven black paint all molding removed.
    all chrome stripped and gun-blued
    aluminum diamond plate covering all lower body panels teflon painted.
    rhino or bedliner painted inside body panels,underside.
    then start building a slingshot to have something to tow!
    goodluck
  6. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    87 v20 Suburban 5.7tbi, th400, np 208
    Install 5" lift with tuff country springs, ORD, and misc stuff
    Istall Lockright in D60
    Rebuild Dana 60
    Install Dana 60
    Install 14bff
    Replace bent flexplate and front seal on tranny
    Replace dead fuel Pump
    Install superduty shocktower, and buy front shocks
    Build pre-runner style front and rear bumpers
    Cut fenders
    Buy offroad lights
    Bigger tires
    1" body lift
    Someday: ORD doubler or similar upgrade.
    Upgrade exhaust
    GM HO350 Crate engine w/TBI manifold and mild cam
    Bucket seats
  7. FLASHLIGHT76
    FLASHLIGHT76 1/2 ton status
    Jun 20, 2002
    255
    OREGON
    Oh this is too much fun!!!!!!!!!!!!!!!
    Soon: New bumpers front and rear, trimed fender wells, sliders with hindge up and down steps (for the wife), winch on front off of telephone company truck, new engine mounts and trany mounts (old ones worn out), spare tire hung out back, pro comp stainless flood lights up front, body lift is debatable, and some more cool neon interior lighting (just to keep the import guys jealous).
    Down the road: Looking at multi port fuelinjection with 100 shot nitrus (variable setting for low R power), headers, rino lined interior and under carage, ground up restoration (cab off frame), loud pipes (so everyone knows when I'm there), confer roof rack starting at the back of front doors and going all the way back, flood lights off of rack to light up around, interior roll cage all the way back ( posibly exoskeleto design if I can figure out how to reinforce and keep light), and all of those other ideas I havn't finished designing yet. /forums/images/icons/grin.gif
  8. FLASHLIGHT76
    Jun 20, 2002
    255
    OREGON
    my list was alittle short only because I have done alot already!!! /forums/images/icons/smirk.gif Although I do have to ad D60 front with crossover steering. A must!!!!
