Rochester 750cfm Q-jet problem
Discussion in 'The Garage' started by Paxx, Nov 7, 2003.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    Last time I drove my truck it ran fine, just a little on the rich side due to the stock housing being put back on. When I went to take it out last night it started up but then would die after start up. I figured it was due to the cold so I started it again and kept revving it for a while giving it a chance to warm up, then as soon as I'd let go of the gas it would stall again. I fired it up and this time decided to drive it a ways. It felt like it kept wanting to bog out on me. thought it might have been low on gas, took it filled it up went to drive away and it stalled again. Took the air cleaner off and found that it had been spitting gas out. it was inside the air cleaner and all over the top of the carb/engine. ended up tightening the screw on the linkage to get it to hold idle a bit better which seemed to help some, it held idle for about 15 to 30 sec before dying this time. Decided to get it home, got there and it stayed idling at 1000rpm when I got home and it didn't die /forums/images/graemlins/confused.gif What is going on with my carb???
  2. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Dang, that sucks. <--carb joke. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    It's really hard to know for sure without looking at it and knowing some more details but I would start by looking at your float. Make sure it's still floating /forums/images/graemlins/grin.gif and make sure the needle on the end of the float is able to fully seal in the seat. This is the same type of symptoms you would have if you had some crud holding that needle off the seat.
    Also, make sure you check your choke linkage to make sure it's working. Once the engine starts, it should open up a little bit to let air in and as it warms up it should open all the way.
    /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cold start problem would be due to choke open too far
    is it electornic or hot vacuum tube air or hot intake manifold spring type ?
  4. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Check float/Needle/Seat/Choke as was stated before. I'd also spray the linkage with WD40; on my carb, the high idle (used when the engine is cold, linkage on pass. side) does not always like to engage, in most cases due to gunk on the linkage. You also might want to adjust the high idle speed rather than regular idle. I usually do this for winter, set it at 1500-1800, although this year I've vowed not to drive the truck anymore due to salt on NE roads....
