ROCK guys i need some help!!
Discussion in 'The Garage' started by ilikeitloud, Mar 15, 2005.
  1. ilikeitloud
    ilikeitloud 1/2 ton status
    Oct 30, 2003
    134
    edina, minnesota 55424
    memorial weekend is goin to be the next time i go wheelin so im scramblin to get my rig ready for it. this year though i would love to tackle the rocks. everytime we go to dresser every1 in my group wil bypass the rocks but i wanna drive through them. im tryin to set my rig up more for tackling the rock sections and i would love some feedback as to what i should do to "prepare" for them. I was thinking some dif guards for the front and rear. obvioulsy lockers for front and rear. i have 42in tires on right now with 410 gearing but unfortunatly(sp) i wont be able to afford new gears before i go out wheelin. im goin cross-over/hydro-assist as well.Ive never ventured into the rocks myself so if ya guys have any other tips on what to do in the rocks or any other ways to "rock-proof" the rig it would be greatly appreciated,
    thanks matt
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    sliders are a must.... good flex.. let see, what else... lol those are good starters
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    yea I say flex and just knowing your rig and its tipping points and such. another tip is to go very easy on the throttle, I like to push on the brake and push the gas some then let off the brake very easy, this will alow you to have more control over where you go. With 42's you will ge good as far as ground clearance, just watch your tie-rod and such.
    One hting that you might do to get some extra traction is to groove your tires. Just a thought :)
  4. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Sliders, armor, and be ready for impact. The first time you crawl you will think there are hooks under your rig.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    For the rocks you need lockers, gears, and armor. You do not need alot of crazy flex to rock crawl. It can be nice to have but you don't have to have it. It can definitly hurt you sometimes also.
    Harley
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Hmmmm, I would say a upgraded tie rod and definetly have some sort of T-case protection. I only have 35's so I tend to smack the x member a lot on break over obstacles. With 42's you shouldn't have too many problems. Make sure you always have a good spotter as they can see things you can't obviously.....this can make or break whether or not you can clear an obstacle. Oh ya, and have little regard to body damage:grin:
  7. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    if you running a carb....it needs to be a q-jet....the others suck off camber...
  8. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Good call on that one, I had an edlebrock for a while and it would stall on some scary obstacles which would cause me to lose braking and steering assist. Not a good mix when you are climbing stuff like this
    I went to a Q-jet and haven't had any problems since!
  9. Ryan B.
    Jul 18, 2001
    5,693
    CA
    yep, beefy diff covers, gas tank skidplate, sliders..
    Spare axles and driveshafts? :grin:
  10. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Lockers for sure and other than that just do it!
    After a run or two you'll know what you need for the rocks in your area. :waytogo:
  11. ilikeitloud
    Oct 30, 2003
    134
    thanks for the tips guys!!!!!!!!! im lookin forward to hittin the rocks:D
  12. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    1) everything under the rig needs to be armored. If you can lay down on the ground and look up and see it, assume that at some point a huge pointy rock will hit it. Skid plate accordingly, especially diff covers, tcases, gas tanks etc.
    2) armor yourself with a cage, a good quality seat and a harness. If you're doing really narly stuff, get a cheap skater's helmet to protect your noggin just in case.
    3) gears. I have 4.56s with a 205 and a 700R4. In 1st gear my crawl ratio isn't low enough for rocks. I can drive them, but its like: jerk forward..brake..jerk forward...brake, repeat. I plan on going 5.13s and a doubler. Low gears don't just give you mo' torque at the wheels, the real benefit is the control they give you by slowing the rig down at normal operating RPMs.
    4) steering. big tires will get stuck in between rocks... you need hydro assist or full hydro to make sure you can actually turn. Also, your steering linkage needs to be beefy enough to take hits from big rocks. Steering arms from WFO will let you relocate your tie rod behind/above the axle, that would help.
    there is other stuff... but thats prolly the most important 4.
    j
