Rock Logic question
Discussion in 'The Garage' started by readymix, Jun 1, 2006.
  1. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I searched and no one has mentioned this before so here goes.
    On the RL 1.5" ram like what Jesse (BlazenOffroad) sells are hte heim ends rotatable? Basically can I mount the ram so that the lines are verticle and rotate the heim ends so that the mounting bolt could be verticle or horizontal or anywhere in-between.
    Also I remember someone posting up about not being happy about the lines supplied in the RL kit? It was just the length of the lines that sucked right? Jesse's newest posts states that it comes with 48" lines.
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Heim ends swivel so yes you can mount the ram with the hole in the heims both vertical or horizontal.
  3. readymix
    May 30, 2004
    6,706
    26
    Sweet, thanks. Now I just need to save some $$
  4. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    It's worth every penny that you save too :D
  5. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    yes, thats why heim joints are favorable, many mounting options. And yes 4' lines.
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I am in the same boat as you Brian specially with the weld job we are about to put on my front. That RL kit is looking better and better.:D
    Ira
  7. readymix
    May 30, 2004
    6,706
    26
    Hopefully soon I can get it. I am kinda torn between buying rear 56's so it will flex more than 5 inches, or doing the HYD Assist...:thinking:
  8. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    What's the point of flexing if you can't steer? :)
  9. readymix
    May 30, 2004
    6,706
    26
    Well as it is now I can steer. It is not too bad even with the Detroit up front.
    The rear flex is another matter. No matter what I do it will not flex.
    Plus springs are cheaper if I get them used.
