rock ram install?
Discussion in 'The Garage' started by carolina custom, Jul 16, 2002.
  1. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    I have a used arg rock ram on the way and am looking for ideas and pics for install on a d60 with ORD x-over and stock tie rod. Any one got god links?
    Marc
  2. BILLY RAY
    BILLY RAY 1/2 ton status
    Dec 8, 2001
    1,319
    Austin, Tx.
    Take a look at my web page I have a hand full of pics. of the ram install on it. If you need more let me know I will snap some and send them to ya. /forums/images/icons/grin.gif
  3. carolina custom
    Dec 29, 2001
    161
    Mt. Pleasant SC
    Thanks Billy, where did you mount the ram to axle and tie rod? Can you use any of the mounts from the steering stabliser? I am thinking of using the tie rod stabliser mount and welding brackets on the dif tube near the cover?
  4. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
    I used the brackets that Matt sent me. One side was welded to the axle tube the other welded to the rock-stomper rock rod. If you are using the stock rod. then you can use the hole where the stab. bolts up, you may need to make the hole a little larger. If you have any more ? just let me know.
  5. carolina custom
    Dec 29, 2001
    161
    Mt. Pleasant SC
    I think I will have to use the stock rod for now. I dont think I will get any brackets, but was planing on fabing my own.
    Thanks, marc
  6. BILLY RAY
    Dec 8, 2001
    1,319
    Austin, Tx.
    If you are getting the set up from AGR they will send brackets with the kit. If you are getting a used set up I will snap some pics. of mine they are real easy to make. /forums/images/icons/wink.gif
