rock ram steering
Discussion in 'The Garage' started by highrider_44s, May 4, 2004.
  1. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    Can you drill and tap a stock steering box to work with a hydrolic ram. if you can where do you drill. also would a pump for a hydroboost braking system have enough preasure to run a ram. /forums/images/graemlins/crazy.gif
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
  3. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You might have to run dual pumps since you have hydroboost, some people don't have to though... /forums/images/graemlins/thinking.gif
  4. rvreddog
    rvreddog Registered Member
    Oct 14, 2002
    67
    San Antonio Texas
    I did the mods listed above plus I used a smaller pulley on mine and it does just fine. I imagine the lower your gear ratio the better it will work.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Where did you get a smaller pulley?
  6. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    probably won't run the hydroboost brakes just the pump.
    I was told that it pumped lot more preasure no? /forums/images/graemlins/dunno.gif
  7. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    Has anyone drilled there own steering box where do you /forums/images/graemlins/hack.gif the holes
  8. chubbybob
    chubbybob 1/2 ton status
    Oct 18, 2002
    730
    I have hydraboost with a ram and it works fine you dont have to do anything to your pump.
    remember that if you do mod your pump you will likely burn it up a lot faster than your stock pump and putting an underdrive pully on to speed your slow steering up will deffinitely burn it up. that comes straight out of matts mouth from wto.
    he told me there will always be one down fall to this system
    1. either your steering will be slow at an idle or
    2. you can speed it up with an underdrive pully and it will burn the pump up much faster.
    I chose a slower steering at an idle when you need it to turn faster touch the throttle.
  9. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Read this /forums/images/graemlins/waytogo.gif or search for "hydro assist" there are quite a few posts on this /forums/images/graemlins/peace.gif
  10. rnss82
    rnss82 Registered Member
    Mar 28, 2004
    22
    oregon,wa.
    i think pierate 4x4 has a good info on it in there /forums/images/graemlins/thumb.giftech site
  11. highrider_44s
    Mar 28, 2004
    392
    southern B.C.
    I checked out that info /forums/images/graemlins/waytogo.gif good info but My box is out of a chevy and i think they have a toy box /forums/images/graemlins/dunno.gifthe mounts are right in the way of drilling the top hole /forums/images/graemlins/doah.gif If thats even the right spot to drill and what pasage are you trying to hit for the top hole. i think the bottom can be drilled there if the lines don't get tangled /forums/images/graemlins/confused.gif
  12. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    Marine pumps have smaller pulleys.
