Rock Ring Question
Discussion in 'The Garage' started by IGOR, Feb 20, 2003.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    Those of you running Avalanche Engineering Rock Rings - on your 14 bolt - does the ring "nestle" inside the lip around the outer edge on the OEM cover, or do you need to grind the lip off on the OE cover?
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    You have to grind the lip off so the outer rim is completely flat.
  3. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    FYI - sometime in the last few years (I think when they introduced the HD body style) GM started producing the 14 bolt cover without the lip.
  4. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Okay but isn't the 14 bolt for the HD style trucks different - I believe those are an 11.5" ring gear?
  5. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    They actually offer 2 rear axles now, the 14 bolt (10.5" ring) and a new 11.5" ring gear axle. The bigger axle comes in the 8.1 BBC and diesel applications.
