Rock Rod length
Discussion in 'The Garage' started by cegusman, Nov 4, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What length Rock Rod do I need to get for my dana 60. It will be mounted in the stock location.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Call up Rockstomper, he'll be able to help you best. But I know when I ordered mine he said it was the same length as Steve was using on his D60 and I had a D44 at the time. And now hae the same Rock Rod on my 10 bolt.
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I can measure my MOO rod. Quick question for you. Why use a presumably weaker rod <font color="red"> correction</font> that has the two tubes welded together, when you can buy a rod from Missouri Offroad Outfitters that is 1.5" diameter x .375" wall and is tapped through to about 6" depth. Steve does this so if you ever want to cut your rod down for High Steer - you don't have to purchase another rod. To cut down a Rockstomper rod, you would have to weld in another insert. Just FYI - disregard if you aren't interested.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Rockstomper rods are threaded, they don't use an insert.
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Thanks everyone, the length is 52".
    Why use a weaker rod that has welded in thread inserts, when you can buy a rod from Missouri Offroad Outfitters that is 1.5" diameter x .375" wall and is tapped through to about 6" depth
    I am not buying one from rockstomper, or any of the other sources mentioned. I am getting on from TONYP, his don't use inserts either.
    Chris
  6. Mudzer
    3,639
    Missouri
    Bah!
  7. Mudzer
    3,639
    Missouri
    Chris
    Doh! /forums/images/graemlins/rotfl.gif
  8. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    I'll wander out to my rig today and measure my rockstomper rod...
    j
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    A Rockrod from Rockstomper is (2)pieces of tubing sleeved.(one inside the other) for strength. They are welded together at the ends. Then the inner tube is tapped for the TRE threads. They dont use an insert that is just welded on the end.
    You can cut down a rock rod to any length and just reweld the ends and re-tap it.
  10. Mudzer
    3,639
    Missouri
    This is off topic now that we know he is building his own tierod - but. Why go Rockstomper over the Missouri Offroad Outfitters in any case?
    Two pieces of tubing sleeved is not stronger than one. The MOO rod is thicker wall thickness. It is tapped deep so you can cut it down without welding. It also has the harder to find left hand jamb nut included! Less work for cheaper!
    http://www.mo-offroad.com/Tie%20rods.htm
    http://www.rockstomper.com/catalog/steering/rockrods/rockrod.htm
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    Both are about the same price. Actually the MOO is $180 with ends and the Rock Rod for GM's starts at $175 with ends. And the Rock Rod also comes with the harder to find left hand jam nut included. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
    Now I may be talking out of my ass as I dont have any backgorund knowledge info... But to me it seems it would be harder to bend two pieces of tubing sleeved than one... Even if the one is .036" thicker. But I am sure someone may prove me wrong...
  12. NetBlazer
    NetBlazer Registered Member
    Apr 23, 2001
    90
    Littleton, CO
    Additionally, Rockstomper offers a CK5 discount
    CK5 discount
    Sean
  13. Emmettology 101
    May 9, 2000
    8,126
    FL
    Actually I believe MOO does also as he is a CK5 member.
  14. Mudzer
    3,639
    Missouri
    True Dat! /forums/images/graemlins/grin.gif
    10% off to CK5 members.
  15. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Why not get a rockrod from Echobit its only $86 (without ends) and also has left handed threads on one end.
  16. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Thats is the one I am getting, TONYP makes them.
  17. Emmettology 101
    May 9, 2000
    8,126
    FL
    What is the wall thickness on those? They aren't really any larger diameter that stock(maybe 1/4") except for using stronger material. And once you add in the tie rod ends they are basically the same price as the others yet smaller and possibly weaker.(no offense to anyone).
  18. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    I wish I would have ordered mine from Steve...
    Much faster turnaround...
    It took 3 weeks to get mine from Rockstomper...
    and Scott said he had one in stock...
    I'd rather deal with Steve...because he's NOT affraid to be honest!!! /forums/images/graemlins/wink.gif
  19. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    the MOO vs Rockstomper is, IMO, a bit like the old ORD vs Echobit shackle flip posts. Both are great products... both are CK5 discount-providers... both are good people. IMO, you cant go wrong either way. I personally have a rockstomper rod. It aint gonna break, and thats all I really care about. /forums/images/graemlins/thumb.gif /forums/images/graemlins/laugh.gif
    j
  20. 88jimmy4x4
    Oct 19, 2003
    947
    3
    Houston, Texas
    Replace your stock bent tie-rod bar with a 4130 chromoly bar that you can lift your truck with.Chromoly tubing is 25% stronger then DOM
    What material do the "other" guys use on their rockrods?
