Rock Rod People
Discussion in 'The Garage' started by Hossbaby50, Apr 18, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am getting a rock rod made, and I was wondering how I can put a steering stabilizer back on my tie rod? I am retaining stock style steering for now, and would like to get the stabilizer back behind the rod like on the factory setup. Anyone done this or have any ideas on how to do this?
    The ends that are coming with the rod aren't going to be drilled like the factory end to take the stabilzer bolt. My rock rod is going to be set up with righthand righthand on the tie rod ends if this makes a difference. Thanks
    Harley
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Scott (RockStomper) and Steve (MOO) both make bolt on mounts for the rock rods. Since you gotta take it loose to adjust the ends anyway, why not just weld on a tab?
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Russ has got a point Harley...just have Timmy boy weld on a tab in the stock location...you you and I could fab something with some little u-bolts and some 3/16" plate /forums/images/graemlins/thumb.gif
    Chris
  4. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    Make your own tabs that way you'd be good to go. BUt make sure it is aligned before you do any welding that would stink if you needed to make a 1/4 turn on it at the last minute. just my .02c
    KEN
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    I was hoping to stay away from the ubolt setup if possible. I think it is kinda cheesy, and was hoping for something more clean, and more HD. I guess it really wouldn't matter that much as the steering stabilizer isn't putting a huge stress on the rod or anything else. Any ideas that are more clean and professional looking I would appreciate hearing them. Thanks
    Harley
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    It doesn't get any cleaner or stout than the MOO clamp. If you need adjustment, you just unscrew the four bolts and the rod turns inside the clamp.
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Only problem with the MOO clamp is that it's frickin expensive for a block of metal with four bolts. Mad4wd over on PBB sells a similar clamp for about $20, but he doesn't have the 1.5" ID ones in stock yet. If you can wait a little while then that would be the way to go. </font>
  8. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    buy and then weld on a couple of tabs... mount the stab to the tabs and go. of just go WTO hydro assist, matt throws in the tabs so u dont have to buy em. /forums/images/graemlins/grin.gif
    j
