Rock Rods
Discussion in 'The Garage' started by Muddytazz, Dec 1, 2003.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Whos got pics of their steering stabilizer mounted to welded on tabs? I'm debating on whether I should go weld on tabs or just one of those clamp on mounts.
  2. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    I just used the clamp supplied with the kit, comprised of 3 u-bolts and a plate. I haven't had any problems with it, but it does look kind of tacky, and I'd rather have a tab welded on.
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    You talking about mounting TO the rock rod? If you are, and you weld a tab to it..........you won't be able to adjust the toe in/out. I use the clamp type on the 'Shane74-built' /forums/images/graemlins/thumb.gif unit and am very happy with it. Did the same with the Rockstomper Rock Rod on my K5.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Gotcha, never thought about that /forums/images/graemlins/thumb.gif Good thing I asked first /forums/images/graemlins/grin.gif
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Dood... I know you checked out my hollister pics 'cause you just replied to my post...
    If you look close i have a rockstomper rockrod and for my hydro i mounted one of those 1.5" clamps from mcmastercarr and welded the tabs onto the clamp..
    That way when you need to adjust your toe in you can loosen up the clamp and rotate the rockrod then tighten back down the clamp... /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
    If you welded the tabs directly to your rockrod you would only be able to adjust the toe by 1 whole turn of the tie rod. /forums/images/graemlins/frown.gif
  6. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    i have the mount from rockstomper that i'm not using anymore if you're interested. send me a PM.. /forums/images/graemlins/deal.gif
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    pm'ed ya /forums/images/graemlins/thumb.gif
