Rock Slider Poll
Discussion in 'The Garage' started by rcamacho, Nov 29, 2005.
Where should I mount rock sliders?
  1. Body mount
    70 vote(s)
    42.2%
  2. Frame mount
    75 vote(s)
    45.2%
  3. Both (with bushings to allow for flex)
    21 vote(s)
    12.7%
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    I'm considering fabricating some sliders for one of my first welding projects. So, is the consensus to body mount or frame mount? My rockers are in good shape so I'm not inclined to cut them out.
  2. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Sounds like you allready know what the answer around here is gonna be :crazy: But, if your not cutting the rockers, then frame mount would be best IMO.
  3. rcamacho
    Jul 1, 2004
    1,324
    WA
    Thanks. Since the frame mount would allow ~2ft of leverage on the frame are there any concerns about tweaking the frame? I'd imagine that the C-section could distort under impact.
  4. mrk5
    Apr 20, 2004
    12,327
    1,031
    Northern Colorado
    I like mine mounted to the body. I did it similar to this from the 4x4 Armor product review.
    If you look at November in the 2005 rigs calendar, you can see me putting them to the test. :wink1:
    I haven't had any problems. I've also seen an extra brace added that goes back to another vertical floor support. Can't really verbalize what I'm talking about and I don't have pics. I know Pauly383K10's sliders have it.
    I'm planning to make a new set for myself that won't cost so much clearance.
  5. mrk5
    Apr 20, 2004
    12,327
    1,031
    Northern Colorado
    A buddy of mine had the 4x4 Armor sliders with the frame mounts.
    Personally I didn't like it. When we had his body off, you could put a foot on them and really see how much it twisted the frame. I suppose with the body on, the mounts stiffen the frame some. I didn't like the flex I saw.
  6. BigCountryx
    Feb 19, 2005
    519
    Gonzales, LA
    You may be right, maybe you should just cut your rockers off afterall :wink1: :doah: :haha:
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I personally prefer the body mount versions simply because you don't have to deal with all the leverage exerted on the mounts if you attach them to the frame.
  8. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I have mine body mounted. I have set the whole truck on them more than once. With as much as the frame twists and contorts, you could end up doing body damage with frame mounted sliders.
    John
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Its like our bodies are predestined to accept tube , excuse the mud , don't know how that got there down here :wink1:
    [​IMG][​IMG][​IMG]
  10. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    my sliders are mounted to the body mounts.
  11. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I personally am a fan of and have my sliders mounted to my body where I cut out the rocker boxes. They give you more clearence and don't apply a bunch of leverage to the frame. Mine are tied in like Pauly383's. If I am not mistaken he got the rear brace idea from my truck. I mounted mine like that.
    I suggest if you do the rocker removal that you add on the brace to the rear like mine and Pauly383's and add a brace to the from of the slider as well. This is especially true if you run a kicker tube like me. Body metal isn't incredibly strong so you need to reinforce the slider so that it doesn't try and tweak and twist off under heavy hits.
    I personally only have the rear brace and got by with just the rear brace installed but I recommend not being lazy like me and doing it right.
    Here is a pic of my sliders and kicker tube. They are made from 2 peices of 1.5" .250 wall square tube welded together side by side and have a 1" .120 wall kicker tube to help keep the body clear of rocks. They work very well except I have bent the kicker tube in several places from hard hits on rocks. They survived though and still work very well.
    http://image12.webshots.com/13/2/8/94/157520894ZjTDvC_ph.jpg
    Harley
  12. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    when i build mine they will bolt to the body and weld to the frame. if you spread the load out on the frame with big enough plates it will be fine. i think using both is the best way.
  13. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    I'm going to attach mine to the body, similar to the way the guy did on offroad.com. I may tie each end of the slider in to my cage's floorplates (lower sandwich plates...) though. IMO that makes much more sense than reaching all the way over to the frame for support. The cages A and B pillars are going to be coming down in that area anyway...
    j
  14. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I have a pair of 4x4iron sliders and they are welded to the body, had the old rockers cut out. Been used and so far they have supported the truck just fine.
  15. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Mine are body mounted similar to pic in MrK5's post. They work just fine.
    I only have 33s and 2" of lift so they have been used a lot. :D
  16. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I just had another thought. I am going to fab up a long thick L brace to the frame to support the frame and not to lose clearance. I could also weld braces onto the frame boxing it in.
    I love having a welder.
  17. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    OFF to go WHEEEELLLLIIINNNNN.
    C YA>
  18. rcamacho
    Jul 1, 2004
    1,324
    WA
    Update 11/07:
    Finally picked up some 3/16" 2x3" rectangle tube and 3/16" 2x3" angle iron. I'll post up pictures as I build. Amazing, 60+lbs of steel for less than $100.
  19. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Looks like you work on the same time frame that I do. Here is what I did.
  20. HOPPER
    HOPPER 1/2 ton status
    Aug 15, 2007
    354
    Mesa AZ.
    My rockers were junk so mine replace them. Im going to tie into the frame and body. The frame is obvious, on the body im going to plate the supports and tie them into the sliders.
    Maybe Ill start my build thread.:D
