rock sliders
Discussion in 'The Garage' started by alf4444, May 4, 2005.
  1. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Does any one no of any rock sliders that would sit flush below the door. OR easily be modified to do so. My rockers were pretty much gone :hack: so i cut the rest rather than replace them I want to put in some rock sliders but don't want a gap.
  2. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Check out mine on my webpage. Follow the link below. The ones I installed on my truck I wanted to be flush with the body , but not remove the rockers too. I cut the seam of the body and rockers and bolted on the sliders right below the rockers. I designed the brackets for adjustablility, the mounting holes must be drilled depending on how much you want sticking out from the door and how far you want it to hang down or hug the body line.
    sliders
    Jesse
  3. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    SeattleK5 on here makes sliders like that. You can shoot him over a PM. He usually builds / installs them locally, but I am sure you may be able to talk him into shipping a pair..???
  4. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    I just used some 4x2 square tube and it fit well just under the door. All it took was a sawzall, grinder, welder, and an afternoon.
    Drivers side
    Pass side
    Finished product, well sort of
  5. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    nice job joe, that looks awesome. :waytogo:
  6. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    Does it tie back to the frame or only to sheetmetal.
