rock stomper rock rod ends... which is which?
Discussion in 'The Garage' started by jekbrown, Aug 29, 2002.
  1. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    put my rock rod on the other day... didnt even torque the nuts down, I just plopped it in the D60 to see how she looks. As soon as I did, I remembered that the tie rod ends are side-specific (meaning, one tie rod end belongs on the drivers side, one on the passanger side and they arent interchangable). So... one has a grease zerk on top, one has one on the side... which side goes where on the rig? I dunno, maybe it doesnt make a diff... but I'd rather know now than while hurtling down the freeway at 65 mph. /forums/images/icons/wink.gif /forums/images/icons/laugh.gif thanks in advance!
    J
  2. spaceboy
    spaceboy 1/2 ton status
    Jan 14, 2002
    106
    Pearl City, Hawaii
    One of the ends is left hand threads so you can't mix 'em up. I just screwed them in tightened the nuts and and dropped her. Nice and simple.
  3. Mobile_Mechanic
    Mobile_Mechanic Registered Member
    Jul 17, 2001
    88
    Phillipsburg, NJ
    I put the end with the fitting facing up on the driver side. It fits nicely and hasn't fallen out yet.
  4. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    The only difference is the right and left hand threads on them. Which side they're on doesn't really matter at all. I just put mine in so that the grease fitting that's on the side of the TRE faced toward the axle housing, that way it wouldn't get knocked off by a rock or anything.
  5. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    ok cool... just 2 more questions: 1) does it matter if the left hand threaded end (for example) is on one side or the other? 2) I noticed the grease boots are quite a bit different on each end... one is short... the other one is long. I looked at the parts that they attach to and didn't see any obvious clues as to why they would be different... what gives?
    J
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    are they both same brand?
  7. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    purdy sure they are, got'em both from my friends at Rockstomper. I'll post pics tomorow of what I have... that would definitely help. trying to describe a wacky 3d solid via text is purdy tough. /forums/images/icons/wink.gif
    J
  8. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    One end is fer a Dodge, I belive. On my Rock rod I just screwed in the lock nuts and then screwed them into the rod. The orentation of the rod does not matter. /forums/images/icons/grin.gif If you want the zerk facing forward, face it forward, if you want it facing backward, face it backward. Easy squiezie. /forums/images/icons/tongue.gif /forums/images/icons/grin.gif
