Rocker arm ratios, what do they mean?
Discussion in 'The Garage' started by jakeslim, Jul 24, 2004.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    What's the difference between 1.5 ratio rocker arms and 1.6? The heads are late 80's centerbolt if that matters.
    /forums/images/graemlins/1zhelp.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    It is the ratio that the rocker arm opens the valve relative to the cam.
    Lets just say you have a cam that is .325" lift at the cam lobe and you are using 1.5 ratio rocker arms, that means the rocker arm makes the cam lobe lift 1.5 times greater at the valve for a valve lift of .487", the same cam with 1.6 ratio rocker arms would have a valve lift of .520"
  3. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    DU!!!!!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/histerical.gif
  4. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    Thanks /forums/images/graemlins/waytogo.gif Can I use either and is one better option? Its a 350 with stock cam, etc. (87 and up block and heads)
  5. hi pinion
    Sep 25, 2003
    5,354
    You have much to learn baby bird /forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif
  6. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Nothing wrong with 1.5 ratio, this is an easy way to achieve more lift without changing a cam or changing duration. Some racers use 1.6 on the exhaust and 1.5 on the intake and other racers use 1.6 on only a couple different valves that need more time to get fuel into the cylinder because of a longer runner. /forums/images/graemlins/thumb.gif
  7. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I got that one /forums/images/graemlins/yikes.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    I have a nice gear driven 203 if anyone wants it /forums/images/graemlins/rolleyes.gif
  8. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    "don't pee on MY lawn" /forums/images/graemlins/histerical.gif /forums/images/graemlins/peace.gif
    Thanks, I'll go with the 1.5's
  9. hi pinion
    Sep 25, 2003
    5,354
    [/ QUOTE ] /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif FELLING VERY GOOD TONIGHT!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/thumb.gif
