Rocker arm screw in stud Q's
Discussion in 'The Garage' started by Mudbug1979, Jul 9, 2006.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    I had one break, so I had to pull the head to drill it out. I have only drilled it the size of the original stud. Can I get a screw in stud and just tap the hole and put that in instead of trying to press in the new stud? What size does it have to be tapped for and is there a special stud that has to be used since I'm not doing all of them. I running a stock motor, no roller rockers or anything like that. Thanks.
  2. Mudbug1979
    Aug 4, 2002
    439
    bueller
  3. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    use the right studs..
    There are aftermarket screw in studs for stock rockers--Dorman makes them..they have a shoulder on them,instead of a hex for a wrench like the factory screw in studs..I'm not sure about the thread,I think they were 3/8",but its been awhile since I've done one..there are other posts here if you search--"78 Suburban" had to do them in his truck,maybe he'll post up!.:crazy:
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    The hole needs to be tapped for 7/16" x 14. Like was said, there is a screw in stud that does not have the hex nut on it but rather just a shoulder for the stud to stop against and this is the stud you need, it is a Dorman #693-006
  5. Mudbug1979
    Aug 4, 2002
    439
    stud
    Thanks so much for the info. I found it after reading enough posts to get a crick in the neck. Here we go again.
  6. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    I found that extra dorman threaded stud we talked about in the PM... PM me you mailing addy and I'll mail it to ya ;)
