Rocker arm studs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chris1972, Jan 30, 2001.
  1. Chris1972
    Chris1972 Registered Member
    Nov 21, 2000
    22
    How hard is it to replace these. Do i need any
    special tools or what---
    Chris
    www.broadpark.no/~csteinsv/
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    They need to be pulled out with a special tool. Most machine shops will replace them with a screw in style and that requires machining and tapping....
    HTH
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  3. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    I guess you´re changing the pressed in stock studs for screw in studs, right ? In that case you´ll need to mill down the stud boss the same amount as the nut of the screw-in one. Your local norwigan speedshop [​IMG] hopefully has a kit for this operation wich should include a tapping guide. Why are you gonna do this, if I may ask ? The pressed-in ones are ok for a mild performance engine.
    /Andreas
    406cui of pure sh*t[​IMG]
    <A target="_blank" HREF=http://hem.passagen.se/znus/>http://hem.passagen.se/znus/</A>
  4. dyeager535
    26,980
    Just went through this myself, except for new heads. I'll start off by saying that if you are modifying the valve lift or are rebuilding a set of heads, have the studs pulled and screw ins installed instead.
    I was told that as long as I keep the lift on my motor under .450, there is no reason to pull the factory studs. Again, these are brand new GM heads, and I am going to be running a roller cam with .429/.452 lift. Just a FYI, since I didn't want to spend themoney to have it done if I didn't have too.
    Dorian
    My K5 and Chev/Olds tech/links page: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
