Rocker arms
Discussion in 'The Garage' started by Chevy305, Jun 5, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    491
    New Hampshire
    Question: Can I put 1.6 roller tip rockers on my 83 305 without having to machine the heads or having spring binding issues?
    Also I noticed this weekend that I may have 1 or 2 slightly bent push rods :crazy:, what causes this? The engine runs like a champ so there are no adverse effects so far...
  2. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    What cam are you running? If its stock .390/.410 I wouldn't see a problem increasing the ratio. If its more than .450 or so, you might want to check the springs for pressure at open lift, to see if they are strong enough, and don't bind. Its always said whenever you change anything in the valvetrain to check valve to piston clearance, but you should have .100 V/P clearance (most likely more) if its stock stuff. Bent pushrods? how bad, can you see the bend or are you rolling them across a smooth straight bench or glass pane to see it. They are cheap to replace.
  3. Chevy305
    Jan 23, 2006
    11,232
    491
    New Hampshire
    yeah its stock cam. so I don't think I will have any problems.
    I didn't take the push rods out because I would have rotate the engine to the TDC on that piston and my distributor was out so I didn't want to mess up timing. I just rotated the rod with my fingers and there was a slight curve in 2 of the push rods. Plus I don't think you sould be able to rotate the push rods, my valves must need adjusting. thats pobably why there is a slight bend in at least 2 of them.
  4. Chevy305
    Jan 23, 2006
    11,232
    491
    New Hampshire
    How do I know what pushrods I need to buy?
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    yes, you SHOULD be able to rotate the push rods with your fingers, just so there's no "slop" in the movement and maybe barely alittle tension.
    Pushrods? stock Chevy 305/350
  6. Chevy305
    Jan 23, 2006
    11,232
    491
    New Hampshire
    well there was no "slop" in the push rods as you describe it. I should eat my words because my Hilton's manual says to make sure you can't rotate the push rods. and we all know how reliable Hilton's is...
  7. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    funny you mentioned this. I really dont know about solid lifters but when I originally tried the Haynes way of adjusting the rockers I ended bottoming out the hydraulic lifters before the thing would quit spinning. I ended up setting zero lash and the a 1/4 turn extra. Seems to work good so far, but I am going to pull the valve covers and check them next week to make sure that they havent developed any slop.
  8. 4xcrazy
    Oct 31, 2003
    9,472
    5
    The pushrods will spin when they are going up and down, not sure of the reason why they were designed to do this, never really cared, but thats what i have been taught, and always seen out of a sbc with hydro lifters.
  9. Chevy305
    Jan 23, 2006
    11,232
    491
    New Hampshire
    Sorry it was was Hayne's not Hilton's :crazy: :doah:
    I don't know why I thought it was Hilton's
  10. 4xcrazy
    Oct 31, 2003
    9,472
    5
    Maybe cause you just finished up watching "someones" video????????:confused: :D :doah: :p:
  11. Chevy305
    Jan 23, 2006
    11,232
    491
    New Hampshire
    Maybe...
    :wink1: :pimp: :whistle:
  12. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Maybe cause the lifter also rotates. My understanding is that cam lobes are ground with a crown to make the lifters rotate, preventing uneven wear on the face of the lifter. I assume that the pushrod would also have to rotate in order to keep from binding on the lifter.
  13. 4xcrazy
    Oct 31, 2003
    9,472
    5
    YEEEAAAH ! there ya go, i KNEW there was a reason, just wasn't sure of it:D :haha:
  14. Chevy305
    Jan 23, 2006
    11,232
    491
    New Hampshire
    Sorta bump!
    Can I put 1.6 rocker arms on my engine without having to machine the heads?
