Rocker Arms
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77JimmyMan, May 11, 2002.
  1. 77JimmyMan
    77JimmyMan Registered Member
    May 16, 2001
    29
    Southeastern MA
    Im looking to put a set of 1.6:1 ratio arms on my truck. I have newer heads with the self align rocker arms. Does anyone know if anyone makes a set of stamped steel (meaning cheap) self aligning arms? I tried the usual places (Jegs, Summit) bu they only have roller ones for around $180. I saw a set on ebay that were stamped steel self align, the guy said they were made by Elgin Automtive and distributid by Federal Mogul. Id buy them but I cant find anything to prove it. Any input would be great. ~Mark~
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Go to: <a target="_blank" href=http://www.lunaticams.com/>Lunaticams.com</a> Do a search to find them
    They make stamped rockers up to 1.7 to 1 for SBC motors.
    In my opinion you should at least get a roler tip rocker they are not much more than stamped. They really help stop valve and valve guide wear in that can happen when using higher ratio rockers.
    Both Summit and Crane cams have stamped rockers in 1.6:1
    Summit Pn SUM-G6801 $ 66.oo
  3. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    *has puzzled look on face*, i'd try and check with scoggin dickey??, and also, i've got this link (which i'll post) that is a chevy dealership that has a kickass message board (kinda like here)!! /forums/images/icons/wink.gif
    http://www.sallee-chevrolet.com/Discus/board.html
