Rocker boxes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Frogg89, Apr 3, 2003.
  1. Frogg89
    Frogg89 Registered Member
    Jul 29, 2002
    85
    Southern NJ
    Does anyone know where I can find "rocker boxes"? I was told its the entire rocker panel assembly in one instead of the seperate pieces. Mine are shot and Id like to get a set of these. Thanks /forums/images/graemlins/k5.gif
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    AFAIK, they are sold as separate pieces from place like goodmark, LMC, and ChevyDuty...There is the rocker itself and then the"Rocker Backing"
    Chris
  3. Grim-Reaper
    7,385
    Atlanta
    What year are you looking for? your sig say's 89. Rocker boxes were only used on 69-76ish (yes I know the full vert ended with 75 but I have seen a 76 in the junk yard with boxes. not you frogg). On 73 up the rocker backing plate that ties in the bottom of the rocker and the cab supports go to are just flat steel when ordered from most places. You could easily make them.
  4. Frogg89
    Jul 29, 2002
    85
    Southern NJ
    Thanks, A local 4wd shop owner told me that they existed. But, if noone else heard of em then I guess he was wrong!! It is my 89 I was looking to fix.
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    What the 4x4 shop might have meant was a replacement for the whole lower door opening inside and out.
  6. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    unless you are restoring a rig back to its factory look or something, i wouldnt waste the $ on the thin guage metal replacements... just plasma cut the old ones off, and have some rectangular box-tube steel with 3/16" wall welded in to replace it. the guy at www.off-road.com has a write up on this, or atleast he used to. At any rate, with that mod you gain ground clearance... save money... and they are a hell of a lot tougher than the factory poop, which, eventually, will just rust again.
    j
  7. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    I agree 100% if you have cut them off weld on some rock sliders in there place.
