rocker cancer (help!!!!)
Discussion in 'The Garage' started by rwright07, Oct 12, 2005.
  1. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    i bought a 76 k5 this summer
    4in lift 33 bf mtr's
    400sb w/ 40k
    so far have had to get new front DS and various little things
    but the biggest problem i got now is the driverside rocker panel
    in the intentation between the doorwell and the floor its rusted through
    also it seems the body mount is gettin bad
    ne ideas on how to fix on a 16 yr old HS budget?
    everywhere else is solid
    i think i got a real good deal alltogether.... 2500 bucks
    also is neone lookin to sell a 9-10k winch?
  2. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    first thing is to cut out ALL RUST.. it will never go away if left in there.. so buy urself a nice 25buck angle grinder from lowes or home depo and go at it.. then.. if u have access to a welder.. weld in new sheet metal. if not, you can prob get away with riviting in the replacement rocker depending on how big of an area it is, and then bondo over that, after all that some bed liner and undercoating will do the trick... sounds like a nice ride any pics?
  3. rwright07
    Jul 30, 2005
    536
    corporate hobo
    not yet il work on the pics n get back soon... where would u suggest gettin rep. rocker panels?
  4. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    lmc trucks has pretty good replacements..
  5. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    do u have carpet in it? i would almost bet the area right behind the front seats in that lil corner b4 the floor raises up has rust too.. its almost a given in these trucks..
  6. rwright07
    Jul 30, 2005
    536
    corporate hobo
    thanks good tip il look for that
    how much will a new rocker cost from lmc?
  7. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    If you plan on useing it for offroad use you could just cut the entire rocker out and weld in a piece of 3x3 square tubing. That eliminates the rust plus acts as a rockslider. :wink1:
  8. blzrdrvr
    blzrdrvr Registered Member
    Apr 28, 2005
    55
    Las Cruces, NM
    what they said
    reply #2 and #7 were both right...#7 was more hard core..saw that on another reputable site....i did pretty much the same as reply #1..cut out the rust on mine, slapped some primer over the exposed metal, and then riveted some very light aluminum over the holes, then covered that with bed liner, left it black. aluminum doesn't rust as fast, and i got a very good bit of it at the hardware store in 3' rolled up sheeting. i got a lot of it and did the same thing to the entire tailgate! same with a fender and other rocker panel. the aluminum was VERY cheap. and no welding needed. rivet heads were hidden by the bed liner...tomorrow i'll post some pics of my rig for viewing.
  9. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    You'll be sorry!
    I had a K5 the previous owner patched up with aluminum roof flashing..it was easy to work with,only one problem--aluminum+ steel= a battery!--add water,and a little salt,and it will rot 10 times faster than before!--ask me how I know.... :rolleyes: :doah: ...use steel,its worth the extra effort..plus you cant weld aluminum to steel,and it adds no structural strength either.. :crazy:
  10. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    If he uses the aluminum, he'll have to add in a third metal like zinc to serve as a sacrificial anode, making things even more complicated. GO WITH STEEL!
  11. blzrdrvr
    Apr 28, 2005
    55
    Las Cruces, NM
    Nah
    Noooooo...my method eliminates welding..."sacrificial anode" is that what you are meaning? my way is cheap and no welding needed. if he wishes to merely put a good band-aide that looks allright...but the proper way would be to cut it , weld new steel, bondo of fiber glass, sand, paint. or like the other fellow said, use some heavy steel so the trail doesn't make more damage. depends on how he wishes to apply his rig to the trail. I am in no way ready for hardcore trail punishment...so just band aided it to take care of the situation of ugly cancer. can always remove the cheap aluminum and install heavy steel when (if) my rig is ready for the evil rocks. :)
  12. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Ding ding......!
    This is the winning suggestion...
    Marv
  13. blzrdrvr
    Apr 28, 2005
    55
    Las Cruces, NM
    yeah!! like that son!!! feel the PAIN, rock!!!!!!
  14. Inu-Hanyou1776
    Oct 1, 2005
    1,345
    Murphy, NC
    A sacrificial anode is third metal utilized in dissimilar metal installations (steel on aluminum in this case), that's meant to protect one of the two original metals being used, steel in this case. The sacrificial anode protects the steel by rusting away itself before the steel does. That's why it's called a sacrifical anode, it sacrifices itself to protect the other metal from rust. Sacrifical zinc anodes are common in salt-water marine applications of boats and offshore oil rigs.
  15. BURB-STYLE
    BURB-STYLE Registered Member
    Apr 29, 2005
    33
    UTAH
    you could paint the aluminum that would end all the sacrificial anode talk. use a sprayer and paint with poly. in it and you'll be fine.
  16. blzrdrvr
    Apr 28, 2005
    55
    Las Cruces, NM
    wow
    :bow: thank you for the education. i suppose this zinc would be available near water........look at my locale! but zinc must be installed prior to rusting. hmm. how expensive is it? in what forms does it come?
  17. blzrdrvr
    Apr 28, 2005
    55
    Las Cruces, NM
    i simply bathed my aluminum in bed liner. the paint on my rig is goldish-brown (chevy indian gold) so the black looks cool. covered the bumpers with bedliner too...i detest bling, especially on a 4x4 rig. why make it blingy if you're going on a trail? impress the rocks and trees?!?!?! out here we have these long-needled mequite bushes that love to kill tires, scratch paint....etc. and chrome makes one more noticeable out in the boonies
  18. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Same idea as Robzilla's, just a little less aesthetically shocking...
    Looks better than pop rivets and aluminum IMO...
    Rene
  19. rwright07
    Jul 30, 2005
    536
    corporate hobo
    good info i think i will go wiht the steel and weld it into place
    thanks
    still lookin for a 9k lb winch and an ok stereo deck if neone out theres got one
  20. blzrdrvr
    Apr 28, 2005
    55
    Las Cruces, NM
    YEAH!!! that looks good..and functional too..i know the aluminum/rivet/bedliner thing isn't all that great but i was tired of seeing the cancer and had extremely limited resources..not so now. i would do that myself, but i have bigger rats to hunt momentarily..i was blown away by baddog's 4 link system...as i said..looks great and functional too! good job!
