Rocker-Knockers this coming weekend
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KrebsATM02, Jun 25, 2001.
  1. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Went to the steel yard and picked me up some 2"x4" box. Going to make it stick out past the doors a little to afford more body protection and kind of a step. In the future i am going to make bars that follow the top of the wheel well that attaces from the front bumper to the rocker knocker and do the same on the rear. Anyone have any other ideas? Oh yeah, does anyone know the rules governing Oxygen bottles?? I have an old oxygen bottle from 86. I know it cost 13.69 to get it recertified, but it has a name on the collar. Someone once told me if it has a name on the collar, people won't exchange them. Is this true??? And if so can i just get around it by grinding it off??? Or is that a bad idea. Just trying to save me some money here. Thanks - Doug Krebs
    Doug Krebs
  2. KrebsATM02
    Mar 21, 2000
    553
    Sniff sniff, no one every replies to my posts. Guess you guys don't find this interesting. haha later - Doug
    Doug Krebs
  3. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Don't cry Doug. I think it is a cool idea. But it would be cooler if you just bought a set of mine.
    <A target="_blank" HREF=http://www.toyboxoffroad.com>http://www.toyboxoffroad.com</A>
    <font color=red>Land use issues are the heart of our sport.
    Get involved or lose the sport.</font color=red>
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Are you attaching the steel to the body (replacing the rocker?) or the frame?
    '71 Blazer CST with alot of rust
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've exchanged stamped bottles a bunch of times - I recently got a bottle stamped by an entirely different supplier from USAirweld. Most suppliers don't really care, as long as they can slap their own sticker on it.
    If it weren't for bad luck, I'd have no luck at all[​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  6. KrebsATM02
    Mar 21, 2000
    553
    I'm cutting out the rocker below the door, and also cutting off part of the front and rear quarter panel. They will attatch to the cab supports. About the bottle, it is a really big bottle and i think that maybe part of the problem. I'm 6'3" and it almost stands as tall as me. Thanks guys, later - Doug Krebs
    Doug Krebs
  7. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    If it is that tall then it is probably a T oxygen bottle. In the past I have been able to trade down to something more manageable. A K size is not as bad but still big. I think mine is a Q now and considered an owner bottle. You can no longer own a T or K size, you can only rent them and pay a hazmat fee monthly. If they try to stick you with that then definately trade down.
    I thought I was wrong once,
    but I was mistaken
  8. Grim-Reaper
    7,385
    Atlanta
    I think 2x4 is not going to be enough for what your doing. Mine a 4x4 and Depdogs are 3x4. The area below the door once the rocker is cut out is 3x3 roughly. Dep has ended up adding a 4 inch rail to that and I'm probably about to do the same. The protect grat from the bottom but what we are finding is they need to be out a little more to help protect the sides.
    If you go over to www.off-road.com to the chevy section look for project RocKReady. That's Deps truck and he has information on how to do the rockers.
    It's not my damn planet monkey boy!
    Grim-Reaper
  9. CK5
    May 19, 1999
    21,627
    704
    CO
    I agree on letting them stick out a little bit, here is a perfect example on why:
    <A target="_blank" HREF=http://coloradok5.com/temp/holy1.jpg>http://coloradok5.com/temp/holy1.jpg</A>
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  10. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You may not want to run the tubing from the rocker to the bumper because of the flex of the body mounts. It might cause the welds to crack.
  11. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Steve, I know the sol'n for that problem...
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  12. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Are those the same ones as Shawn rescently put on??
  13. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    Mike,
    Are those the rocker bars that you are building (same as the ones on your Blazer?). They are some stout looking bars, I wouldn't mind getting a set of them.
    Russ
