Rocker Panel question 71k5... Is there a lip for...
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by slayer77, Dec 13, 2003.
  1. slayer77
    slayer77 Registered Member
    Oct 21, 2003
    29
    Pleasant Hill Ca.
    the weather strip at the bottom of the door? I mean does the rocker panel sit up above the floor panel? I'm welding in my outer rockers today... If anyone has good pictures of this step it would be much appreciated... I looked through the cancer section and couldn't find a photo of this step. Thank you...
  2. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    I'm not there yet myself, but you have the threshold piece that screws down over that lip. I think the important thing is to line up the outer rocker with the rest of the body. (we are talking about the rocker panel that fits the contour of the door and fenders, right?)
  3. slayer77
    Oct 21, 2003
    29
    Pleasant Hill Ca.
    Yes.... your right... it is the outer rocker... Thanks for your help... Hope your well
  4. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    If you base the location of the outer rocker panel on your floor, you may find that your doors do not close when you are done!!!!
    Due to the fact that your front end has sagged due to the fact that your body is not being held together properly, you may need to make some "adjustments" to the location of your outer rocker panel. To really do it right, reposition the hight of the A pillar w/ a jack (on both sides) BEFORE you bolt everything together.
    Hang your doors and base the location of the outer rockers on them.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
