rocker protection
Discussion in 'The Garage' started by westtexask5, Nov 17, 2004.
  1. westtexask5
    westtexask5 Registered Member
    Sep 25, 2004
    56
    lubbock,texas
    just wondering if anyone has any good ideas on rocker protection... what is the best place to attach and how far do they need to hang out to protect the whole rocker /forums/images/graemlins/wink.gif
  2. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    u looking to buy something, or build something yourself?
  3. westtexask5
    Sep 25, 2004
    56
    lubbock,texas
    build preferably
  4. bigcountryk5
    Mar 13, 2004
    931
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    mine are in my pics in my sig under the mods folder /forums/images/graemlins/thumb.gif
  6. folkenheath
    folkenheath Worthless Trash Premium Member GMOTM Winner
    Nov 12, 2004
    4,269
    159
    Wisconsin
    Hi, I Just noticed your post for the TH400/NP205 combo. I can't post in the tech section, so I thought I would write here for you. I don't mean to post in the wrong one, but I saw thought I and I thought I should help with this info. I did the same swap, I had a 700R4/NP208 in my '83, I installed a TH400/NP205 from a '78, and it bolted right up! The crossmember was in exactly the same position and everything. The stock shifter will work fine for the trans, but you will need a shifter from the NP205 for the t-case, it bolts right to the adaptor, it comletely different than the NP208 shifter. You will also need to run a manifold vacuum line to the modulator on the trans, and install an electric kick-down switch on the throttle pedal under the dash. /forums/images/graemlins/waytogo.gif
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Are you looking for more or less the bolt on style that will prevent dents to your stock panels???? Thats what I think when i hear "rocker protection".. I think the best route to go is with the "tRusty style" rock sliders. But they require cutting out your factory rockers. /forums/images/graemlins/smile.gif
  8. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I wouldn't call cutting out your factory rockers "rocker protection". /forums/images/graemlins/rotfl.gif
  9. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    It is if you put them on a shelf in the garage where they'll be safe. /forums/images/graemlins/rotfl.gif
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    True.. Thats what I figured, but thoguth I would present that option too. /forums/images/graemlins/rotfl.gif
  11. Ryan B.
    Jul 18, 2001
    5,693
    CA
    don't play in the rocks. /forums/images/graemlins/rotfl.gif
    I got some 3x2 .188" wall and capped the ends.. cut my rockes and fenders up 2" and 3" in... then welded that sucker in there. ..pics coming soon...
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    That would be "tRusty style"... /forums/images/graemlins/thumb.gif
  13. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    here ya go
    These attach to the frame, body mounts and lower lip of the rocker /forums/images/graemlins/thumb.gif
    PM me if you need any details
  14. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    Got any pics of the mounts?
    What happens when the body flexes?
    btw, here's a pic of a set of mine.
  15. aj's tonka truck
    aj's tonka truck Registered Member
    Jun 29, 2004
    53
    Who makes these? I would like some for my Jimmy.[ QUOTE ]
  16. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
  17. Sam 10b
    Sam 10b Registered Member
    Jan 3, 2003
    20
    Cut a notch in the body about 6 inches up on the body, just up above the lower door hinges. Then insert a 2 by 4 chunk of metal and weld it up so you lose about 6inches of rocker and it is as strong as the body.
  18. Sam 10b
    Jan 3, 2003
    20
    Where in west Texas are you located cause im in Lubbock so we should wheel and what not.
  19. four_by_ken
    four_by_ken 1/2 ton status
    Jun 9, 2001
    3,806
    Allenton, MI
    How do you attach to the body and the frame and not tear the body apart when ti flexes?
  20. four_by_ken
    Jun 9, 2001
    3,806
    Allenton, MI
    This is what I plan on doing. Just making new rocker panels... but, much stronger!:cool1:
