Rocker rust
Discussion in 'The Garage' started by 79k20350, Nov 28, 2005.
  1. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Ok, im going to be doing a suburban bvuild up in the near futue and dont want to do a 2x4 or 3x3 or whatever rocker. id rather do a slider underneath the rocker. question is, how do i keep my purdy rockers rust free. if i remember correctly chevy made a big mistake and those rockers collect mud and water, no? anyway to keep them rust free? other than por 15?
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Best way I found was to not install the inner parts of the rockers.If they're open at the back they don't collect mud, salt and moisture...
    Rene
  3. 79k20350
    Nov 22, 2004
    7,757
    Ct
    im goin to find a rust free burb so the inner rockers will already be there. what if i cut a slot along the bottom and then painted it, that might do the trick huh?. i know, im in new england... but i have found a few rust free already, just dont have the money.
  4. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I could be wrong but don't the inner rockers provide some sort of structural stability to the cab? I know without rockers at all you can suffer everything from the roof popping to windshield cracking under flex. I can't see how a rocker without the inner rocker can provide the stability.
  5. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    when i replace the rockers on my step sons Jimmy, i didnt use the premade inners, i made my own from 16 gauge.
    after everything was welded in, i folded the lip on the rocker over onto the inner, what flexed before, didnt anymore.
    filled them with instant foam, and used caulk on all the seams.
  6. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Why the foam?
  7. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    the foam, I'm guessing is to keep the moisture out.
    My rockers are destroyed, they're certainly not offering any structural support on my K5. I'm not sure how I'm going to replace them or what with, but one big thing will be to keep sand, rain, salt, mudd out of them, the foam sounds pretty good to me
    Brandy
