Rocker Stud torque specs??
Discussion in 'The Garage' started by arq, Apr 24, 2004.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    anyone know what the torque specs are on rocker studs for a set of WORLD S/R torquer heads
    thanks,
    ARQ.
  2. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    what kind of cam? hydro or solid?
    By the way I belive you are looking for valve lash not torque specs.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    He wants the specs for the studs--screw in studs. You don't torque the rocker arm nuts, you have to adjust your valves correctly, it's not a torque spec.
    Unfortunately I don't know the spec, but I figured I'd clarify your question for you in case someone knows what you're talking about.
  4. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Found it
    Rocker Arm Studs: 50 ft. lbs
    they are the 042670-1 hydralic..
    ARQ.
