Rocker Studs
Discussion in 'The Garage' started by kerwinq, May 9, 2004.
  1. kerwinq
    kerwinq Registered Member
    Jan 25, 2004
    20
    Boise, Id
    Just installed a new cam with 488/510 lift, and 1.5 roller rockers. Do I need to have the rocker studs pinned or changed so they are actually threaded in? I have been told yes and no so am not sure. If this needs to be done which is the better way - pins or actual studs? What is the cost of doing this?
    Thanks, Kerwin
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I personally would go for the screw in studs. Can't say if you need them or not, but I prefer them.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I agree, screw in studs. Especially with more lift than stock. /forums/images/graemlins/k5.gif
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Stock studs will usually hold up to about .500" lift but spring pressure also has a lot to do with it. Screw-in studs are much better than pins and I would reccomend doing that. Also buy a GOOD set of ARP's. As far as cost to have it done, I charge $125.00 labor in my shop for doing it.
  5. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    You did not say what kind of spring pressure you are running. if stock you might be ok. Any thing else and I would go with ARP screw in studs
