rockers loose?
Discussion in 'The Garage' started by aj_tatted, Apr 13, 2004.
  1. aj_tatted
    aj_tatted 1/2 ton status
    Sep 6, 2003
    183
    arlington, tx
    i slammed a sbc 350 with 882 heads into my truck.
    however the problems is,...the rockers keep loosening up.
    why would they do that? could it be possibly something to do with the lifters?
    i'm afraid that if i have to tighten them one more time i'm really gonna [darn] something up. /forums/images/graemlins/weld.gif
  2. alaskanbowtie
    alaskanbowtie 1/2 ton status
    Feb 15, 2004
    112
    ALASKA
    use new rocker nuts and you'll be fine, or use some poly locks for added security! good luck /forums/images/graemlins/waytogo.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep most likely the nuts are just not staying in place, time for new ones and/or new studs too
    good luck
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Check the studs they may be pulling out of the head if they are not the threaded style.
    This will cause the lifters to slack off , be re-tightened until the studs pull out of the heads /forums/images/graemlins/eek.gif
