Rockrod Ends?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by SuperUnknown, Feb 28, 2001.
  1. SuperUnknown
    SuperUnknown 1/2 ton status
    Feb 8, 2001
    165
    Prince George, British Columbia, Canada
    I got a quote from NAPA for the tie rod ends used with a rockrod. The Dodge one was about $30 which is what I would expect, but the GM end is more then twice that price.
    Is this normal, or should I go etls where for the ends?
    [​IMG]I spend more time under my truck then I do in it.[​IMG]
  2. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    hey, heres what i was quoted from schucks(pac. NW)
    85 1/2ton 4x4 rod ends, L and R, under $30 each. whats this about using a dodge end?so it doesnt have the hole? like shawns uses, 1 91 dodge 3/4 ton? im thinking ill use the 85 chev pass side(Right side) and the 91 dodge 3/4 ton driver(LEFT) side. my tie rod and drag link are almost done (1.5 dom tubing for both)
  3. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    I was quoted $38.99 for the ES2010L and $24.99 for the ES2233L. This was from Autozone. Anybody find them cheaper?
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I would NOT skimp on the parts you buy for your steering components! Get MOOG!! Who cares if they cost 55 bucks a piece! You do not whant the cheep pot meatel china crap to break on you, do you? Save your money and buy the GOOD stuff!!
    my .02c
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  5. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    WHAT EXACTLY IS A ROCKROD?
  6. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    A very tough tie rod for your front axle. There is a write up on the main page.
  7. misfit
    Jul 21, 2000
    324
    got my right side, right hand threaded(7/8-18) end from an 85 chev 1/2 4x4, the left hand side)LH thread, same pitch) from a 91 dodge 3/4 ton 4x4(4500lb axle, not 3500) and these will be going on my rock rod. should i make a drag link with both RH thread or R and L?
