rockrod users please read
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by misfit, May 20, 2001.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    has anyone installed the rockrod on an axle with the earlier knuckles((ie, the tie rod goes in from the top, nut on bottom) it looks like it might rub the springs.
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    nope, but I'm getting ready to... I'll let you know you how it goes... I think it will work OK. I'm also putting it in w/ a BDS 4" lift so it's won't be a stock setup either.
    <font color=blue> Jeff </font color=blue>
    [​IMG][​IMG]
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I found some early knuckles for my 44 when I was building it .I installed it and then installed my tierod.I almost couldnt install it cuz it was so close to the springs.As to what rod ends I would use with a rock rod I dont know cuz I couldnt use some that come straight off the knuckle .They would have to drop down a bit like the ones I got now so they would clear the springs.
    All work and no beer makes Frizz a dull boy
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Me! I have the RockRod on my 72K5 and yes it is close but it doesn't hit the spring pack. It gets closer when turned left but again it doesn't hit. I have only gone wheelin once sence I installed it and I have not seen any signs of the bar hiting, ie scratches or dings.. I have Rancho 4" leaf springs up front and a Rancho steering stabalizer.
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  5. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Were you able to use your stock ends.I thought that it took a certain later model end that was straight.
  6. Burt4x4
    6,854
    Yes they are the stock tie rod ends. well I bought new ones and they are Moog brand. From what I hear Moog is supose to be the best.
  7. BIGDEAL
    BIGDEAL Registered Member
    Apr 16, 2001
    27
    Waycross GA
    i put one on my 1990 1/2 ton sub. but i put it on from the bottom up, with the nuts on top. it works good but it hits the tire weights on the inside just a little.
