Rockrods
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by morphed86k10, Jun 27, 2001.
  1. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    I'm going to get a rockrod and was trying to decide what ends to use. Should I do like the writeups I've seen and go with the left 91 dodge end and the 86 GM end or just use GM on both ends. Does the the drivers side GM end (with the stabilizer mount) really weaken the assembly that much? I'm running 33's with the stock power steering. Is the added cost (special stabilizer mount, getting the different ends) worth it?
  2. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    well I did the rock rod with the dodge ends etc.
    I'd say if you don't have any problems with you current tie rod why upgrade??? but if you are going to convert then why don't you do it right???
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  3. morphed86k10
    Jun 25, 2001
    463
    Reno Nevada
    because the tie rod on my donor 8 lug dana 44 is pretty bent...thanks though, I think I'll go with the dodge ends too.
  4. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    don't forget to order the bolt on unit that attatches the stabalizer to the rock rod...
  5. jamiemac
    jamiemac 1/2 ton status
    Mar 26, 2001
    151
    Tennessee
    I bought a rockrod from rockstomper.com. Man I got that thing in and it is a massive piece. They say you can jack up a K5 and it will not break or bend. You can get it w/ opposite treaded ends for easy alignment or same on both ends. It is built out of 1.25 DOM. steel tubing then you can get a optional 1.5 DOM steel tube slid over that and full circle mig welded at each end. Thats the one I got. Man it is awsome. Here's a link to there site.
    http://www.rockstomper.com/catalog/steering/rockrods/rockrod.htm
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What would you have to do to make that necessary? I understand that it's stronger, but is it really necessary?
    Tim
  7. jamiemac
    Mar 26, 2001
    151
    Tennessee
    I take it that you never have had to drive home with a bent up tie rod. It doesn't take much to bend one. Drop off a ledge onto a rock. You'll see what I'm talking about.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sorry, no rocks here.
    Tim
  9. morphed86k10
    Jun 25, 2001
    463
    Reno Nevada
    Optional? I just called and ordered asked to order a rockrod...they didn't mention anything about an optional 1.5in tube being over it...am I going to get a weaker version because I didn't specify the outer tube when I ordered?
  10. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    A Rockrod is a Rockrod is a Rockrod is a Rockrod. [​IMG]
    You will be OK
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
  11. Emmettology 101
    May 9, 2000
    8,126
    FL
    There is only one version of the Rockrod. You will get the massive sleeved unit.
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
