rockslider & floor repair spy pics..
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Ryan B., Nov 20, 2004.
  1. Ryan B.
    Jul 18, 2001
    5,693
    CA
    A few pics of some progress on my K/5..
    I started by hacking out the rusty passanger side floor area.. right where the front part of my cage bolts to.. and the outer rocker panel to see what kind or rust i was dealing with...
    I stole Greg72's idea (Thanks Greg!) and made a 1/4" plate then welded nuts to the bottom side of it so i don't have to hold a wrench on the bottom side anymore to bolt/unbolt the cage. And this will be much more supported in the event of a rollover, compared to my rusty floorboards.
    Looking at my cab support it was pretty rotted out, so i reinforced it with some 2x2 which fits perfect inside the cab support.. i notched the cab support for the plate, welded that 2x2 in there then the 1/4 plate to that 2x2 and cab support. To get the reinforcing plate to line up just right with my cage, i had to remove the cage, cut the floor and trim a new section, then put the cage back in to mark the holes on the new floor.. /forums/images/graemlins/smirk.gif
    I stuck another piece of 2x2 under that, capped the ends, and welded the 2x2's together, and to the rocker box.. The capped end of the lower 2x2 will give a place for my rockslider to be butted up against and welded to, tying my cage support and rocksliders together somewhat.
    replacement floor panel in...
    Then on to the rocksliders.. I stole Burt4x4's idea for this.. Thanks burt!
    I got some 3x2 .188 wall thickness, about 12 feet for $20. Cut the ends at an \angle/ and capped em..
    I tack welded in a new reproduction rocker panel, then cut it up 2".. and followed that line on the front and rear fenders cutting up 2" and in 3"... Then I used a couple of floor jacks and started lifting up the side of the truck by the rockslider a little before i welded the 3x2 box tubing to the body.. I removed the outer rocker once it fit good. I welded the rockslider to most all of the inner rocker slowly, like 1" beads at a time, with the outer rocker removed... then on the back side everywhere i could weld it.. I still need to weld the very bottom of the rocker box to the slider, but its in there good.
    I also made the sliders a little over 1" short for the front and rear.. then i trimmed the fenders to match the angle when i was done. /forums/images/graemlins/pimp1.gif
    It's fun trying to do these kind of repairs and mods on your daily driver. /forums/images/graemlins/rotfl.gif
    Now on to the drivers side..Most of my inner rocker is rotted out on that side. /forums/images/graemlins/frown.gif /forums/images/graemlins/thinking.gif
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/hack.gif
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Lookin good. When do you want to coem do mine?!? /forums/images/graemlins/thumb.gif
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Why is it so rusty? I thought most vehicles didn't rust in Cali? Did it come from somewhere else? Good work regardless! /forums/images/graemlins/thumb.gif
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    my k5 had this rust when i first bought it 6 years ago..
    Its in pretty decent shape, i don't consider it that bad. the only real rust was at the bottom of the A piller where water would collect at the floor board and rocker, and eventually rust over time. right where the front part of the cage is bolted to, what a great place /forums/images/graemlins/whistling.gif.. if you check out the cancer support group sticky post up top, this area is a pretty common rust area for most of these first gens. Even out in cali, if the floors and rockers have zero rust you're getting a score.
