Rocksliders....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddin4fun, Feb 20, 2001.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I'm trying to figure out how to have a functional rockslider and step. I plan to put a 4" lift on a blazer (when i finally find one to buy). Or is a good ole "heave hoe" in order when boarding? I don't want nerf bars.
    [​IMG] Keep your feet dry [​IMG]
  2. CK5
    May 19, 1999
    21,624
    702
    CO
    Check out my review on the SEC rockliders, you can have steps that are removable.
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  3. Gandolf
    Gandolf 1/2 ton status
    Aug 8, 2000
    764
    SF Bay Area
    <A target="_blank" HREF=http://www.coloradok5.com/secrockslidersreview.shtml>http://www.coloradok5.com/secrockslidersreview.shtml</A>
    '89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
  4. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Are the steps a pain to remove?
  5. CK5
    May 19, 1999
    21,624
    702
    CO
    No, not bad just a two pins on each side, you only have to remove them when you 4 wheel, so unless you go wheeling every other day it won't be a problem.
    Steve
  6. K5XLR8R
    K5XLR8R 1/2 ton status
    Aug 22, 2000
    210
    Washington State
    I fabbed my own using the SEC concept of bolting to the framrail....I used 2) 1/2 inch thick by about 6 inch (if you want you could go a little longer I think) long peice of angling bolted to the frame; then welded 2) 4 inch peices of 1/4 inch thick square tubing(might want to go thicker for more heavy duty use) to a nother 1/4 inch square tubbing that was about 3 1/2 feet long. ..My main goal was for a step feature that was cheap...with a little tought I think you could make it stout and beefy-er....I wish I could scan them to show you...I jUST thought of a way to make it better too!!!...damn!!!!!...oh well.
