Rockstomper Beadlock kits
Discussion in 'The Garage' started by DaveCowley, Dec 28, 2002.
  1. DaveCowley
    DaveCowley 1/2 ton status
    Feb 18, 2002
    196
    Provo, UT, USA
    Any of you running Beadlocks welded yourself bought from Rockstomper.com. I need to beadlock my 16.5s. Just wondering about street manners, any problems etc... Seems to be an inexpensive solution and they claim they are the strongest beadlocks. They want $80 per kit. Anyone seen a better solution for a better price?
    Dave Cowley
  2. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    The only other options for 16.5's are Hummer beadlocks, or Trail Ready. If you already have rims, the Rockstomper's will win out for overall cost. Hummer rims will either need new centers welded in to correct the backspacing, or spacers. New centers will run you about $50 plus the cost of the Hummer rims. TR's start around $250.
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    have them on my truck w/ 42's unbalanced---i can get up to about 70 w/ nary a vibration---i was thouroughly impressed.---oh yea--theye are 15" rims
  4. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    very interesting..........idea processing, beadlocks hm, now I want some! /forums/images/graemlins/1zhelp.gif
  5. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I had a local shop build mine. Basically they are the same idea as the Rockstompers, except mine are 3/8" thick steel. I just received the first one for a test fit and leak check. Everything was perfect, except I don't know how to torque down the 32 bolts. By the time I finished with the last one, the first one is loose again. The shop will have the other 3 ready on the first days of January. I'll let you know how it goes. Hand labor is cheap in my country, so they should be less expensive than Rockstompers and I'll save on shipping.
  6. DaveCowley
    Feb 18, 2002
    196
    Provo, UT, USA
    Thanks for the commentary. Sounds like nobody had anything too bad to say. I guess that is what I will go with. /forums/images/graemlins/thumb.gif
    Dave Cowley
  7. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    it took me a good 45 minutes to do the first rim where all the bolts were at the same TQ. once i got the hang of it about 20-25 min. just keep going around and around and around and around again till there all good and tight.---mine were eecommended at 10-20 ft-lbs---so i went 15.
