Rockstomper Rock Rods questions please help
Discussion in 'The Garage' started by TxK5Blazer, Oct 21, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I am looking for a steering stabilizer that will work with my 10bolt and my rock rod my parts house can't find one that will work. I need one extened 18" and compressed 10" it must have eyes on at least one end or both does any one have a part number or know of one that will work in this applicatoin....Jason
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    A steering stabilizer is just a shock absorber that doesn't mind being laid on it's side. I beleive that an RS9000 will work just fine as a steering stabilizer, they can be mounted with either end up, I see no reason why you couldn't lay it on it's side.
  3. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    you need a clamp on style mount or build a mount your self and weld it to your rock rod...i think rockstomper makes one though /forums/images/graemlins/thinking.gif
  4. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I'm pretty sure a steering stabilizer has equal dampening in both directions, while a shock absorber has different dampening rates in vs. out. I would'nt use a regular shock. /forums/images/graemlins/thinking.gif
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    Good point, but an RS9000 also has adjustable damping. Mine felt pretty similar in either direction before I put them on, but that's not very scientific. He could put two on, one facing in either direction so the force is equal both ways. Talk about what an expensive band-aid that would be... /forums/images/graemlins/tongue.gif
  6. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    ~$160 solution
  7. Bushwhacker
    Bushwhacker 1/2 ton status GMOTM Winner
    May 13, 2002
    796
    Indian Trail,North Carolina
    I have a dual pro comp stabilizer I would sell. I had the bracket made at a local fab shop so it bolts right up to the Rockstomper rod. all hardware also. excellent shape. Let me know if you might be interested in it.
    Clay
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  8. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    the rs9000 you can run any way rod up or down so I assume the damping would be the same both way right?
  9. Snowbound
    Snowbound Registered Member
    Mar 12, 2002
    52
    Minot N.D.
    Trailmaster makes a coilover steering stabilizer /forums/images/graemlins/truck.gif
  10. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    have u posted in the wanted forum? surely there is a ck5 member that has gone hydro-assist and no longer needs a steering stab...
    j
  11. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    I beleive that the spring in that works in both compression and tension. Could be wrong, but it wouldn't make sense if it only worked one way.
  12. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    yeah, like me.. and i even have the rockstomper bracket that you need.. /forums/images/graemlins/deal.gif
    you know how to get in touch with me..
  13. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Not any longer. Rancho has quit saying that the 9k's can be mounted body up. They have to be mounted body down.
    Also, whether it's up or down doesn't matter, compression is still compression and extension is still extension.
  14. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I don't have a steering stab. on my truck. After I installed the rock rod I never got the mounts to reinstall it. I was waiting to see if I needed it. I didn't notice any difference with my old tierod with stab. compaired to the rock rod without it. You might not need it and can save yourself some $$$. Worth a shot. Its a free test.
  15. Emmettology 101
    May 9, 2000
    8,126
    FL
    I have run a stock steering stab. for years with my Rock Rod. No complaints.
  16. jekbrown
    May 19, 2001
    45,030
    365
    Vancouver, WA, USA
    get hydro assist... then u dont need no stinkin steering stab.
    j
  17. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    THANKS for all the help guys my parts man did some reasearch too and found one for me this morning so it is on the blazer now will see after work how she rides put it on during my lunch break...Jason
