rockwell axel conversion
Discussion in 'The Garage' started by milspecjimmy, Jan 6, 2003.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    any one do it? chop them down, change em to 8 lug disc breaks? how hard is it and is it worth it if i get he axels cheap enough?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> It's not very cheap when you get into changing them to 8 lug with discs. You also need to run a fairly massive amount of lift in order to clear the top loading 3rd members. I had a chance to get 3 Rockwells for $150 (1 front, 2 rears) a few years ago and did not get them due to the cost associated with the brakes and the fact that I would need a minimum of about 12" of lift to clear the things. I also was not real keen on the 6.17 gears, that in itself rues out any kind of street driving, since you'd need 52" tires just to be able to run at highway speeds.
    You can do the pinion mounted brakes, but they are illegal to use on the road in most states.
    If you do not care about the truck being street legal and you don't mind it being REALLY tall, then go for it, but don't expect it to be a cheap swap if you want to get fancy with the brakes and such.</font color>
  3. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    I know of two people going to this style of setup real soon theBigdaddyof2 and Blueblazer62 on the forums here. You may also check with Steve Sharp for any questions you may have yellerblazer@hotmail.com and lastly check with Casey at Wagoner Machine in Oklahoma www.wagonermachine.com
    Steve has this under his '72 K5 at this time - custom suspension, but in the beginning it was leaf sprung. I would not waste the money converting to 8 lug - go with pinion brakes, hydro steering and the standard 6 lug setup. MRT makes the beadlocks for this application. You can run 15" rims with the pinion brake setup.
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Speaking of thebigdaddyof2, he just picked his up last night, I hope to get some within the month. I think 6-8" of lift will be plenty if uptravel is limited by lowered bumpstops.
  5. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    a place in florida called chucks trucks has done this and offers turn key jobs, although it isn't real cheap /forums/images/graemlins/shocked.gif
  6. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
  7. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    "After getting stuck twice in the sand trap on his last golfing trip, Jim Bob decided he needed a bigger golf cart."
  8. Mudzer
    3,639
    Missouri
    What? Todd bought the axles? KEWL!
