Rockwell Axles....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90blzr, Sep 7, 2001.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Can someone explain what exactly the Rockwell parts are or give me some backround on them or somewhere where I can check it out. I dont know very much about them, other than they are some big @ss mo' fo's!! Just curious. Thanks!
  2. Ryeguy
    Ryeguy 1/2 ton status
    Oct 30, 2000
    Victoria, B.C.
    They are (I believe) 2.5-ton and 5-ton rated. The pinion comes in over the top, above the ring gear (but not vertical). Talk to Boyce, they advertise in the big 4x4 mag's. They're good for coolness factor, but very heavy and have huge drum brakes.
    --Rob
  3. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Yeah, I dont want them, just want to know about them. thanks
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    You don't want them, but you want to know about them?!?! [​IMG]
    Come awwnnn!!! You want some and you know it!!! [​IMG]
    Those axles are "top loaders", meaning the axles power is fed from the top. It goes down to the ring gear via a "third member" in which the pinion is residing.
    Gear ratios for the 2.5 tons are like 6.72:1 and the 5 tons have like two different ratios. Something like 6-something and 10-something.
    Boyce can supply just about any set up you want. Get a catalog from them. I have one and gave one to Rene when he stopped by on his "famous trip".
    <font color=blue>"Ya don't have to beat it, ya know!!!</font color=blue>
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
  5. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    90 are you refering to the ones in the sale forum?
    I have seen these axles in jamiemac parking lot of his shop and man Im telling you the differential area ( the pumpkin) is bigger around than my 33's tires[​IMG] F'ing LARGE!!!!!!
    They look like they are in good shape though
    tRustyk5 for President!!![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  6. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Yeah, those and just all of them in general. I keep hearing of them, but I dont know anything about them, just that they are F'N huge! I was just wondering if there is a site, or anything that tells what they are exactly, what they came off of, you know just backround type info.
  7. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Theres a post about them on Pirate, in the General section.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  8. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    Hey thanks Pete!
    So these things just came in Military trucks? I saw 2 or 3 got them out of 6x6's. Is that all they come in? And that pinion brake sounds interesting, do you happen to know of a close up shot of that? So on these axles, I saw if you want to run a "normal" size rim you have to remove the drum brakes, but does that mean that the only brakes you can run are the pinion brakes?? These things are interesting[​IMG]!!
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Mychal, call Boyce Equipment and get one of their catalogs. It will show you pics and everything they do and can do to the Rockwells. Good catalog too, just the prices suck though! [​IMG]
    <font color=red>I'm a "black top mudder"!!!</font color=red>
