Rockwell or D60?
Discussion in 'The Garage' started by guido666, Nov 10, 2005.
  1. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    D60s seem to be so much, why not just get a Rockwell? Any downfalls to the Rockwell? Or the other way?
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    Rockwells are obsurdly heavy... and they have 6.72 gearing, so you need a 44" tire, minimum...
  3. 350k5
    350k5 1/2 ton status
    Feb 15, 2005
    115
    Bloomington, IN
    Really heavy and big. Also it has some pretty high gears, 6.72 and you will want to have some seriously large tires on there. Over 44's I think. And you would probably have to do a lot of modifications make those things fit.
  4. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Why? I would think just enough lift so that the pinion doesn't hit your engine. And driveshaft mods of course.
  5. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Military tires are far cheaper then civilian ones though. So 46" tires are no problem.
  6. 350k5
    Feb 15, 2005
    115
    Bloomington, IN
    Yeah, your right it woudln't be a lot of mods, but I doubt it would be very easy to do so. 2 1/2 ton axles under a 1/2 ton truck... my guess is they don't just bolt in.
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Please search, this topic has been covered countless times.
    Ill break it down for ya:
    Need to push the axle forward about 6" to clear the oil pan.
    Will either need alot of lift or redesign the engine crossmember to clear the top loader chunk.
    Dont forget the odd lug pattern and if you plan to run military wheels better get military tires while your at it as finding a radial type tire in that size will be next to impossible.
  8. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Anyone here do it? Considering that axles only connect to the truck at the springs, the driveshaft, the brakelines, and the drag link, how hard could it be?
  9. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Sorry, we were both posting at the same time. I did search, but didn't see anything in the first several pages, so I figured I would ask. :doah:
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Rockwell axles either need to be converted to disc brake or pinion brake... pinion brake isn't legal in most states.
    A Rockwell steer axle with its drum brakes stripped off weighs the same as a Chevy 60.
    You need a lot of lift to clear the toploader.
    The axles are pretty wide.
    They don't turn very sharp. You pretty much need to run two steer axles.
    By the time you get enough lift to clear the toploaders you need big tires... which means you want to keep it wide for both stability and turning reasons... soon it doesn't fit a lot of places and isn't streetable.
    The initial cost is cheap. It's everything after it that it gets expensive... especially if you don't want to be trailer trash.
  11. guido666
    Feb 16, 2005
    788
    Longmont, CO
    Fair enough. Someday I'd like to build something with them. Maybe I'll just buy a Duece & a Half. What fun that would be! :D
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Took me about 10 seconds to find info on them.
    page 2
  13. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    one name: Ouverson. 2" shafted rockies own all. :thumb:
    j
  14. guido666
    Feb 16, 2005
    788
    Longmont, CO
    I read that one. Didn't really answer the questions I was asking.
  15. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I was going to. I had a source for 2 "runable" rockwell steer axles for a grand. Rockwells are more suited to 53s and a tube buggy. Where I live now that doesn't make sense.
    I ended up buying a Ford HP60. I'll end up having about as much money tied up in it but it'll be streetable.
  16. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    yea and they will plow over a field of money trees :D
  17. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    cheaper than a 300m 40-spline D60 + ctms would be...
    j
  18. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    6.72s are actually low gears... higher number = lower gears
  19. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    He meant numericaly high.
  20. 54inches
    54inches 1/2 ton status
    Feb 9, 2004
    1,535
    Houston, Texas
    The last statement is 50% true, the initia investment is cheaER, but from what I have read (and not actually expeienced) it is a ton more difficult to break these than a Dana or 14 bolt.
    I mean you abuse anything, it is going to break after awhile, but these things are BEASTS.
    Please correct me if I have misrepresented any information. I am still learning as well.
