Rockwell Pattern Wheels!?!
Discussion in 'Parts & Trucks Wanted' started by OffRoader93, Apr 4, 2005.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    I need a set of four 20"x10"-14" wheels with a 2.5 ton Rockwell pattern. They can be beadlocks or plain steel. Don't have to be perfect. Just need to function. Any help would be great. PM me or call me at 1-309-231-6105. Thanks.
    Brenton
  2. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    Which style of bead do you need? Are you going to run 14.00 or 16.00 tube type tires?
    If you are, then you need the truck or "civilian" style bead. If you are going to run the tubeless 12.5R20's, you need the so called "military" style bead. The latter is mis-named because it is actually the same as the current automotive 20" wheels that are so popular. I am currently running a set of 12.50R20's on american racing "mojave" wheels and they work great, except in snow. Sources for these wheels are John at Stazworks, and USA 6X6.
    From what I've heard, Stazworks reputation is very good, and USA 6X6 is questionable. Hope this helps.
    Jimbo
  3. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    try chuckstrucks.net thay have a forsale section and also new ones. thay do 2.5 ton swapss and more.
