Rockwell's
Discussion in 'The Garage' started by txfireman110, Jan 21, 2004.
  1. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    Rockwell\'s
    Help me out here.... /forums/images/graemlins/1zhelp.gif
    Found some Rockwell 2 1/2s... /forums/images/graemlins/thinking.gif
    1.Can you run whatever size tires you want?....
    2.How hard would it be to stick them under an '80 K10?...
    3.What are they worth?....
    4.Do they have lockers in them?
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    Re: Rockwell\'s
    1. The military runs some pretty hefty tires on those things. 44's wouldn't be a problem at all. I don't see 48's or even 52's as a problem.
    2. Hope you like a really tall rig. Since they are a top loader design, you're gonna have to get that engine crossmember above that unless you want to bump the pan on the top of the axle. No idea as to how much lift, but I'm guessing quite a bit. 10"??? Maybe. Just guessing there.
    3. I've seen them go as a complete set WITHOUT rims for anywhere from $1500 to $3500 from private sellers.
    I hope that helps. Boyce Equipment has all kinds of rebuild stuff for them. I'm sure they could answer any specific questions you have. Good luck with it!
    Kris
  3. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Re: Rockwell\'s
    Would you have to go as big as 44's or would say 38's be doable????
  4. mud390
    Oct 31, 2002
    1,210
    Re: Rockwell\'s
    Depends on how fast you want to be able to go. If I remember right, those axles have something like 6.71 gears in them, or something really close to it. So, with 38's you won't be going very fast down the road, but in the dirt, you could crawl all over anything. Don't forget about the rim issue.
    Kris
  5. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Re: Rockwell\'s
    Rim issue?????
    Tell me about this please....
  6. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    Re: Rockwell\'s
    With 6.72 gears in the pumpkin, you will be turning some serious RPMs with 38's, even 44's will be spinning the engine pretty fast. IMHO, if you just want to run 38's, skip the Rockwells. I have seen them go for as little as $700-800 for a set in good, used condition. They have open diffs in the military trucks, but Detroits are available.
  7. mud390
    Oct 31, 2002
    1,210
    Re: Rockwell\'s
    They are a 6 lug rim is the axles are from a 2 1/2 ton (duece) truck and (i think) a 10 lug from the 5 ton truck. The lugs are really spaced out. I don't remember the exact messurements on them. I've seen a couple places that make rims for them so you can run 15, 16, or whatever you want to run on them. If you want to have 20 and be they can do it, but its all in what you want. All the wheels I've seen have been steel.
    Kris
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Re: Rockwell\'s
    Why would you wan't big heavy rockwells if your only thinking 38's? Heck a beefed up front D44 or 10B with CTM's and aftermarket shafts can just about handle 38's along with a 14BFF in the rear...
  9. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Re: Rockwell\'s
    I'm not stuck on 38's, just curious if they would work till 44's came into the poor man's budget!!! /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  10. mud390
    Oct 31, 2002
    1,210
    Re: Rockwell\'s
    With gearing like that I think I would opt for something a little taller if your budget would allow. Is this for a trail only rig or a street driven rig (occasionally/regularly)? If you look around enough you can catch some good deals on some Michelin military tires that are taller than 44's.
    Kris
  11. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Re: Rockwell\'s
    Trail Only (if need be)
    !!!** What would it take to put them under a K10?**!!!
  12. mud390
    Oct 31, 2002
    1,210
    Re: Rockwell\'s
    You might try searching on pirate for this. I read a bunch of stuff on there about it when I came across a set for a really good deal. Once I realized what it took to put them under my rig, which was WAY more than I wanted in every way, I passed on the deal.
    Kris
  13. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Re: Rockwell\'s
    OK, i'll check it out tommorow, going to bed now though. /forums/images/graemlins/crazy.gif
    THANKS A TON for the help!!!!!!!!!!!!!!! /forums/images/graemlins/thumb.gif
  14. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Re: Rockwell\'s
    I have hear that the top loader can hit the pan on flat ground with a 6". You can always move the axle foward about 9" and fix that with a 3 link. You will quickly out run a poor mans budget and tap dry another mans budget to boot. This is all my opinion so no quotes followed by wrong, "blah blah blah"
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Rockwell\'s
    Think so? Try it. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Four outings, two broken u joints and stubs. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/eek.gif
    If I was gonna run Rockwells, I'd run MICHELINS! That's what's made for them. They come in both 49 and 52 inch heights that'd be ideal for Rockwells.
    Otherwise a properly beefed D60 can pretty much handle 42s or 44s in most cases. My buddy managed to break his 35 spline D60 with a power-loc and 44" boggers, but he beat the piss out of it for a long time and it just finally broke.
  16. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Re: Rockwell\'s
    You didnt have CTMs and chromemoly shafts did you?
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Rockwell\'s
    No, the '60 upgrade was cheaper. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
    Then again, mine is open. It had all the chance in the world to survive with good joints and being an open diff. Snapped the joints right in half.
  18. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Re: Rockwell\'s
    [/ QUOTE ]You have a totally stock front axle...new u-joints or not it's still stock. I would bet that a 10B with CTM's and chromemoly shafts would have held up with your 38's. With a 38" bogger maybe not but with anything else I bet it would. I agree though that it would just be better to get a front 60 instead.
  19. txfireman110
    Nov 1, 2003
    294
    San Angelo, TX
    Re: Rockwell\'s
    OK, NO Rockwell's... /forums/images/graemlins/tongue.gif
  20. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    Re: Rockwell\'s
    quick question from a new 4x4 owner, what is CTM?
